Question about Apple iBook G4 Mac Notebook
My G4 screen shell is starting to detach from the casing
My G4 screen shell is starting to detach from the hinge and screen. The LCD works just fine, I'm just not able to close it, as it bends the plastic. Is there a way I can take this apart and fix it myself?
  • 25 Answers
You can remove the back of the screen lid with the 4 hex screws located along the sides of the screen. Once the screws are removed you can remove the back of the screen with a spudger or by flexing the screen assembly starting near the top. Once removed you will find the screws securing the clutch assembly to the screen. If the screws are loose you can tighten them. If they are stripped or broken you will need to find a replacement hinge/clutch assembly on Ebay. Good luck
Posted on Sep 10, 2009
How do you replace a laptop screen l555d serial number...its a toshiba.
1. Turn off the computer and remove the battery.
2. Loosen the plastic frame bordering the Toshiba Satellite L555D-S7005 Screen. This frame is attached to the notebook's back shell and holds the screen in place. Pry open two to six small rubber seals from the frame and undo concealed screws.
3. Detach the frame after removing all screws. Hold the bezel from either side of the screen and gently pull it away from the screen and toward you. If the bezel seems to be stuck, find any points of attachment, such as clips or hooks, and undo to detach it from the outer shell. Work with your fingers and go all around the frame to release and completely detach it.
4. Free the LCD panel from its position in the notebook's lid. When you remove the bezel, you will notice that the screen is held in place, enclosed in hinges. Undo screws from either side of the screen to release its attachment to the lid. Place a finger at the top center of the screen to keep it from falling down as you remove the screws. With all screws undone, tilt the panel and lower it face down onto the keyboard.
5. Disconnect the power cable and video cable from the screen. The power cable connects the screen's power source of the lcd inverter to the backlight lamp attached to a side of the panel. Unplug cables from either end of the inverter board and unscrew the board from the base of the screen. Next, find and unplug the video cable a broad, ribbon like arrangement taped to the back of the panel. Pull at the plastic head of the cable to detach it.
6. Remove the screen. With the screen's cables unplugged and inverter board removed, it is completely detached from the notebook's display assembly and may be safely removed. Pick up the panel from the keyboard and keep it to a side.
7. Orient the replacement screen by bringing it to the work area and aligning it to the laptop's shell. Gently rest the screen on the keyboard and attach the power cable and the video cable. Raise the screen and attach the inverter board to its base. Plug in the inverter board's cable to the screen's backlight lamp. Screw the screen in place and reorganize the display assembly.
May 04, 2011 | Toshiba Computers & Internet
I want to get to the motherboard. how many screws are there?
1 Wear an antistatic wrist strap before you start dismantling the notebook. Doing so will prevent static electricity from damaging internal components.
2 Shut down the notebook, and remove its AC power cord and battery. Turn the laptop over and remove all marked screws from the bottom. Raise the plastic shells covering the hard drive, memory (RAM) and wireless card slots, and uninstall the components by lifting off the base. You may have to release locking clips to free the RAM module from its slot.
3 Turn the laptop around and detach the keyboard panel. Using a flat-head screwdriver, push inward on the four small latches holding the keyboard in place to disengage them. Lift the keyboard to remove it, and disconnect its flex cable. Remove the five screws from the exposed landing. Do not undo the screws securing the heat sink and CD-ROM drive.
4 Split the notebook casing open. Insert a pointy or flat-tipped implement between the top and bottom parts of the casing, and maneuver to detach the locking mechanisms holding the two parts together. Work your way all around the perimeter to detach and remove the top casing. Do not apply too much force, or you may break the plastic parts.
5 Remove the hinge covers holding the LCD panel. Unscrew the two plastic hinges to loosen the display assembly and its enclosed LCD screen. Locate and pry open the CMOS battery---a flat, circular component resembling a watch battery---from the motherboard. Disconnect the LCD cables, and detach the panel from the laptop by lifting it up from its position.
6 Undo all securing screws from the chipset and heat sink. Remove the components by gently raising, checking to ensure that you've disengaged all attachments. Remove the CD-ROM drive by unscrewing its attachment and detaching it from the notebook. With the optical drive off, disconnect the speaker's connecting wires and remove the speaker assembly.
7 Unscrew all points of attachment to release the motherboard from the notebook's chassis. Locate and undo all locking mechanisms, such as clips or hooks, to free the motherboard. Remove the plastic inserts for the modem, as well as the PCMCIA and SD card slots, and detach the motherboard. Move the board around a little to release it, and lift it off the notebook.
Feb 05, 2011 | LG E500 Express Dual Series Notebook PC
My LCD powerbook G4 has a white vertical line
This is usually symptomatic of a chafed or pinched LVDS cable, especially if the line comes and goes as you work the hinges. This not a user-replaceable part. If the line does not flicker when the hinges are moved, there is a possibility that your LCD screen itself has gone bad.
Nov 24, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Replace hinge on HP Pavilion dv9000 labtop
Check out this WEB site on how to replace a hinge on a laptop. It may not be exactly the same model as your laptop but the principles are the same, Click on this link :-
http://www.insidemylaptop.com/
Sep 09, 2009 | HP Pavilion dv9000z Notebook
Nintendo DS hinge broke
You can find the info for replacing the shell here:
http://site.powergamingparts.com/RepairNdsl.html
Dec 22, 2008 | Nintendo DS Console
Top screen blank
yes you will need to replace the top lcd screen and the shell hinge
All parts found on ebay
Sep 08, 2008 | Nintendo DS Console
Mac Mini G4 Flickering Screen at Start Up
Did you check the wires?  Sometimes if you pull one loose it flickers.
Aug 13, 2008 | Apple Mac mini G4 Desktop
Nintendo DS - New case/shell - The hinge..?
that could be a little bit out of my league, find a call centre number they are usually helpful and give you step by step info
Jack
Apr 09, 2008 | Nintendo DS Console
Apple iBook G4 Mac Notebook Logo
428 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
