Question about HP OfficeJet 4215 All-In-One InkJet Printer
Computer doesnt recoginze port
The 4215 has been connected for two or three years no problems. I moved the computer to another room in the house when I went to reconnect the 4215 printer the computer does not recognize the port?I have he install disk I put it in again does not recognize the port . This is the sane port it has been for years. please help me............
Re: computer doesnt recoginze port - HP OfficeJet 4215 All-In-One InkJet Printer Printers & Copiers
Posted on Jan 05, 2008
  • 104 Answers
Hi, It might be a good idea to completely uninstall the printer from your computer altogether, also unplug it and then restart your PC. Then shut it back down and then plug the printer back in and restart. Are you using Windows XP if so the PC should see the printer when it boots and will require instalation. Please note if your printer originally required you to first install the software before attaching the printer to the PC then you should follow the original instalation requirements. Let me know how you go.
Posted on Nov 08, 2007
0 characters
3 Points
How to install my printer?
Can you confirm that it's an HP OfficeJet 4215 printer?
What OS and type of device (computer, phone, Mac, PC, Windows version, ...) are you trying to install it on?
How are you trying to install the printer?
How are you connecting the printer to your computer? (USB, network, Bluetooth, Ethernet, or ?)
Have you tried to install it, and if so, what happened? Exactly what error messages did you get?
Here is a link to the drivers for the HP OfficeJet 4215 all-in-one if that helps you get what you need without answering all the questions above: Drivers Software
Jul 28, 2014 | HP OfficeJet 4215 All-In-One InkJet...
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215 all-in-one "remove and check left cartridge"
uninstall all existing printer driver on your computer..maybe you have two or three driver installed..
an then..
install compatible driver to it..
May 12, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP Officejet 4215 will not print
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Mar 29, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Hp 4215 all in one printer
Firstly is it a new printer ?
What operating system are you using ?
Did this problem start when you used the printer for the first time?
If it was working before but now has problems, then did you update the printer drivers before this happend?
Feb 08, 2009 | HP OfficeJet 4215 All-In-One InkJet...
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
I have anhp officejet 4215 and the director does not work
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | HP OfficeJet 4215 All-In-One InkJet...
DELL A960 Printer Driver
There are two downloads for the A960 all-in-one. Just click the link below. Click the plus sign under the statement-
(2 Items - Use the Category filters above to narrow your results.)
If you list the model number of the XPS, I can post a link here for your Lan drivers too.
Please vote...
Jan 29, 2008 | Dell A960 All-In-One InkJet Printer
How to fax
You would need to connect a phone line from the appropriate port on the all-in-one to an open phone jack in order to make faxing work. If that's a problem, you can use the scan feature and send docs by email as a workaround. If you want to get incoming fax service, though, you will need the phone line connected to the unit.
Aug 14, 2007 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
