Question about Maytag NMPEB08F2A Air Conditioner
Model M6P09S2A Maytag Portable Air Conditioner/Manual?
Model M6P09S2A Maytag Portable Air Conditioner How do I get a manual?
I have the M6P09S2A Portable unit that is leaking water everywhere. I have to place it in a large bin to keep it from draining on the floor. Any solutions?
Posted on Jul 20, 2011
Why is our a/c blowing room temp air when the setting is on cool?
It sounds like the compressor is not running. This could be due to a faulty thermostat, a bad start capacitor for the compressor, a bad compressor overload or simply a bad compressor. You would need a voltage meter to check all of these components.
Jun 20, 2014 | Maytag Portable Air Conditioner M6P09S2A
How do I drain the water from unit before storing
Drain from valve at the bottom of the back of the unit. Look at page 6 of the instruction manual here: http://usermanualnmpeb08f2a.yolasite.com
Aug 25, 2012 | Maytag Portable Air Conditioner M6P09S2A
Needing the hose attachment to the window kit
I believe you'll find what you need at the following link. http://www.appliancefactoryparts.com/airconditioners/maytag/m6p09s2a.html If you can't find it there, try Sears Parts Direct.
I hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Maytag Portable Air Conditioner M6P09S2A
My daughter gave me her portable air con, can't find the manual and was wondering roughly how much water to put in it. Hope someone can help me with this. Thank you.
Mam, you don't put any water in it. This A/C Unit has a dehumidifier in it, that takes humidity/water out of the household air, which helps make the room cooler.
Feb 04, 2011 | Maytag Portable Air Conditioner M6P09S2A
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
Top tray not draining
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
Jul 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
Window insert is missing
write down the model and serial#'s and call maytag and see if they have them most of the time you will have to order them online there should be a contact number for maytag on the unit or the paper work
May 25, 2009 | Maytag Portable Air Conditioner M6P09S2A
I need an instruction manual
After much research, you are going to have to call Maytag. Here is their contact info.
http://www.maytag.com/support/contact_us.jsp
Mar 23, 2009 | Maytag Portable Air Conditioner M6P09S2A
Leaking in the maytag m6p09s2a*b
Do you have the Manual to read the trouble shooting page?
How old is the unit?
If not here is a web site to acquire the manual
http://homeappliance.manualsonline.com/ex/thread/view/idThread/326907
Bless you ngafm Waiting for you answer!
Aug 21, 2008 | Maytag Portable Air Conditioner M6P09S2A
Maytag NMPEB08F2A Air Conditioner Logo
4,353 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
