Question about Remington Polesaw Wizard
Coupling collar The coupling collar on the pole broke and I need to know where I can get a new one
  • 188 Answers
You may have to get a whole new pole, beacuse i do not think that the coupling collar is available anymore. I suggest you contact Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps you!
Posted on Jun 30, 2009
I need a Coupling Nut for my electric pole saw
lots of luck there, if you have tried Remington, with no luck may i suggest a automotive hose clamp and a piece of inter tube.
Nov 07, 2013 | Remington Electric Pole Saw
I need coupling collar for my remington pole saw
I experienced the same problem with mine. The collar ring split making the pole saw useless. I am one of those who can basically fix anything you can put into my hands......
I have the solution for you! Loosen the collar ring and ensure the matching edges (where it is split) are clean & dry.....(no oil or residue).
Use JB-Weld (available in most department stores, hardware stores and auto suuplies) to repair the collar ring. Use the standard type epoxy (not the fast drying type). You will also need one other item to keep the ring from splitting again. The collar ring has a 2-inch diameter. Go to a hardware store or an auto supply store and ask for a 2-1/2 inch stainless worm clamp. Be sure to get the wider type that is about one-half inch across the stainless band. The clamp is typically used to connect radiator hoses on automotive engines. Make sure the clamp you get is stainless. Unscrew the clamp using safety in mind.....they typically have a large "straight slot" screw; using a screwdriver is a bit dangerous especially if you have to tighten it very tight. If you have access to a nut driver or a small quality socket set, these tools will enable you to tighten the worm clamp very tight. Do not force the collar ring back into service for a few days to ensure that the epoxy has had plenty of time to cure. I repaired mine a few years ago and it still works great!
Please send me a reply once the surgery and recovery is complete.
The total cost for materials is about $9-$10.
I hope this fixes your collar ring for good!
How to remove a drive shaft on a ski centurion 1990 ski boat. I bent the shaft that connects the prop to the motor.
Hi, remove the rudder. Then undo the three grub screws on the engine coupling. They are at 90 degrees to the shaft and lock the shaft into the coupling. There will also be a small collar rear of the coupling that you need to take off the shaft. Then slide the shaft out. All this has to be done with the back of the boat raised clear of the trailer. Hope this helps, regards Phil.
Jul 18, 2011 | Boating
I have a whirlpool WFS1071BW & the bowl doesn't turn, so it won't spin to wash or spin at all. It still drains fine though.
sounds like you broke the motor coupling,also the model number you sent doesn't come up.remove the two screws that hold the top console down,flip up the console,remove the two metal clips and unplug the harness closest to the right clip.open the lid,grab the frame tilt it up and back and the whole frame can be removed.look at the bottom,remove the two clips and slide the pump off,do the same to the motor and on the back you'll find the motor coupling.most likely it will be broke.remove the other half off of the tranny.install the new coupling and you should be fine.if you need anymore help let me know
Jan 23, 2011 | Whirlpool Washing Machines
Female coupling on pole broke. need replacement
Bad Design, You would need to replace complete pole. Costly Available at 1-800-654-8534
Nov 09, 2010 | Remington Polesaw Wizard
Problem with Kenmore Washing Machine.
IF your coupling is broke then put a new one on and see, but without a coupling then you dont have a washer period. Whirlpool is very good make if a new coupling does not work and you can hold the tub while it is spinning then you have a bad basket drive. but put a coupling on and then put it in spin, bypass the switch with a ink pen or something and try holding the tub if you can then its the basket drive if not your good to go.
Apr 19, 2009 | Kenmore Washing Machines
Kenmore Washing Machine 110.20722990 Will not agitate or spin. Took it apart and found a broken coupling between motor and gearcase. Does this mean gearcase is out?
no u just need to replace that motor coupling u just take pump and motor off take broke coupling off put new back on be as good as gold
Apr 19, 2009 | Washing Machines
Broke the coupling to our blender #KSB50B3
If you have a Kitchenaid Blender (model KSB50B3 or similar) and the rubber teeth on the coupling (that spikey rubber thing on top of the base) broke off (see picture), here is how you can fix it yourself! The Task: The coupling is screwed onto a vertical shaft like a button mushroom. The shaft is round with two flat sides. You need to find an U-shaped thing [such as a wrench] to secure the shaft and loosen the coupling by turning it CLOCKWISE. What you need: 1. New coupling: Part number KA-9704230. Shouldn't be more than $6. I got mine at www.goodmans.net. Their shipping fee is very decent and the service is also good. 2. An U-shaped object: Some had success with household forks. That didn't work for me. Most successes came from the use of ignition wrenches. There's only about 1/4 of an inch between the coupling and the base, and these very thin wrenches can get in there. You will need size 5/16 or 9/32. I got mine at Sears. They come in a set and are not cheap!! The steps: 1. Rip the rubber cover off the coupling. There's a metal disc inside. 2. Secure the shaft with the wrench. 3. Grab the metal disc with a plier and quickly **** it CLOCKWISE. This is to overcome the inertia. 4. If not loosened repeat steps 2~3. 5. Screw new coupling on COUNTER-CLOCKWISE. Now you are ready to make that smoothe or margarita or what have you again! Disclaimer: Kids, don't do this at home. I am not responsible for any explicit or implicit damages caused by you repairing your blender. Read manufacture's warranty policy before proceeding. Call their service center if you don't feel comfortable performing the aforementioned repair.
Apr 22, 2008 | KitchenAid KSB5 Professional Stainless...
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Remington Polesaw Wizard Logo
184 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
