Question about Whirlpool SF325 Gas Kitchen Range
How do i convert my stove part#9755996 the oven part to lp from gas?
4 Suggested Answers
SOURCE: Converted to LP Gas,How to adjust top & bottom flames in oven?
Open the air vent to the burner, you may have a small delate when it goes on , make sure the burner is clean buy the ignition, or the ignitor it's goin bad, you will know that when the oven takes more then a minute to ignite.
Posted on Dec 06, 2008
  • 33 Answers
SOURCE: How do I convert a Whirlpool super capacity 465
you have to change the little nozzles at each burner to smaller ones and then switch the plastic orfice around in the gas regulator thats on the stove where the gas hooks up.whirlpool should offer the kit to convert this stove.this must be done to insure it work properly.
Posted on Oct 28, 2009
erpaalai
  • 999 Answers
SOURCE: black soot is coming from the burner area in my
Check to make sure the orifices and regulator was changed properly and open the air shutters.
Eric
Posted on Mar 27, 2010
Recently acquired an older Hot Point Cooking stove with self cleaning oven. Need to know if I can convert to propane and how to do so. There were no manuals with the stove..
Stove conversion natural gas to Lp - YouTube
? 6:08
https://www.youtube.com/watch?v=iXX2mS6FrxI
Sep 2, 2014 - Uploaded by Clay Rogers
If anyone can do it so can you. ... Stove conversion natural gas to Lp ... How to Convert Your Natrual Gas ...
Nov 15, 2015 | Kitchen Ranges
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How do u change a gas stove from natural to lp?
Nearly every natural gas / LP operated appliance can be converted to work with the other fuel pretty easily. You will need to change the orifice in the burner & pilot. Contact your LP provider and they should be able to supply the correct parts / perform the labor for this job for you.
Feb 19, 2013 | Whirlpool Stove / Oven / Range Cooktop -...
Recently purchased Frig. gas stove.Want to convert from natural gas to Lp.Do you remove spud and insert Lp oriface in spud then screw spud back onto line?Lp oriface is a lot smaller than oriface for...
Not really sure which model you have but when converting the over, ether bake or broil burner you tighten down the orfice cap. If you remove the burner off the oven valve you will notice that you can put a wrench on the orfice cap. Just tighten snuggly. If you over tighten you will crush the orfice under the cap.
Dec 22, 2009 | Frigidaire Ovens
How to convert from lp gas to natural
Microwaves are electrical only.To convert a stove,range or oven the orfices must be replaced.Insome cases a gas regulater my need to be instaled depending on if your on high or low gas pressure
Jun 24, 2009 | Microwave Ovens
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Swithed to LP
Natural Gas has a pressure at about 1/4oz psi. Propane runs at a much higher pressure 8 psi to 15 psi. For your safety do not use the oven until it is garenteed that the oven is rated for LP Gas!
Hope, this helps, Sea Breeze
Feb 01, 2009 | Kitchen Ranges
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Whirlpool SF325 Gas Kitchen Range Logo
144 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
