Question about Panasonic NN-T990SA Microwave Oven
Panasonic MW- Arcing
If heating fatty substances (melting butter for example), as the product on the turntable gets near the area where I assume the MW waves come out (a square in the center of right side vertical panel inside, covered with a removable panel of some strange material) a brilliant flashing and the sound of heavy electrical arcing (1 to 2 sec., off and on) takes place until the product rotates out of proximity to the panel. I removed the panel and cleaned it pretty good and for a while things were fine. Now it is doing it again and freaking out my wife. She wants a new MW, I want to easily fix it. By replacing that panel with a new one will the problem go away? I had read that food built up on the surface can cause this and cleaning it seemed to help the first time. Ever heard of this?
John Ewers
  • Panasonic Master
  • 9,098 Answers
You're on the right track. That panel is the waveguide cover.
This is usually due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover in the waveguide just out of sight.
It can be fragile, and the metal edges behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
To order Panasonic parts see
Posted on Nov 18, 2007
MCD1611W New, popping popcorn in glass MW corn popper. 3-4 minutes to pop. After popped I open the door and after a few seconds the MW shuts down completely, no lights, no response to pad pushing.
Popcorn is a low-moisture food which can cause a microwave to overheat, as can a failure of the cooling fan or blocked vents.
You should always turn a paper plate upside-down on the turntable (slightly off-center for better heating) and place the popcorn container on top of that.
The paper plate elevates the popcorn for better exposure to the energy and protects the turntable from excessive heat.
Placing food off-center instead of in the center increases exposure to the energy and prevents the same spot on the turntable from being overheated repeatedly, which leads to material fatigue and cracking.
It's also a good idea to put about 1/2 cup of water in a 1-cup microwave-safe container in the corner of the oven when cooking low-moisture foods like popcorn, bacon, and potatoes.
The microwave's magnetron has a thermal protector (thermostat, TCO, or thermal fuse) attached to it.
If the magnetron gets too hot, it can be damaged or destroyed, so the thermal protector opens and disconnects the power to the whole oven.
If it is a resettable device, the power will be restored when the device cools. If it is not resettable, the device must be replaced.
FixYa does not directly notify us experts of responses, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 28, 2017 | Magic Chef MCD1611W
Shuts off after approx 5 - 7 sec. some smoke
If it stops after 7 seconds, it has a problem with the inverter.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you prefer to replace the inverter yourself, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 15, 2010 | Panasonic NN-S954WF Microwave Oven
Panasonic Microwave NNSD277B 5yrs old makes noise after 20sec on (bUzzing and popping)and internal light flashes. Should be replaced or fixed ? what could be the problem?
You should have no arcing within the unit. Assuming you have adequate food/water in the cavity, it should not arc. You NEVER run the unit without something to be heated in it!!!
You might check the stirrer fan which is often in the roof of the unit to see if contamination might be in the area causing arcing. The electric fields in th area are very high and arcs can jump.
If the insulating window is charred or has charred grease, it should bbe replaced.
Dec 26, 2009 | Panasonic Microwave Ovens
Maytag Over The Range Microwave: Melted glass turntable, rollers
Considering the melting pooint of glass ...
Normally, microwave travels around round surfaces (Look at the B-1 for example) If you put flat metal in a microwave, you will create sparks ... lots of em. Is it possible you have something going on with one of the wheels ... like a piece of tin foil?
At a minimum, I think id be inspecting everything inside very carefully and then give it a good cleaning.
You might want a pro in your area tale a look at this as well.
Oct 05, 2009 | Maytag MMV4205 Microwave Oven
Sparks, noise and burning smell
If it is burning and arcing at the antenna, it is probably arcing in the wave guide area. Probably will have to replace unit. I have had some success by removing the antenna, sanding and repainting the burnt areas of the cavity and sanding off any burnt marks on the antenna. Need to look at top of mag to see if also arcing there too.
Jun 16, 2017 | Panasonic NN-2555A Microwave Oven
Electical arcing (sounds - looks like something is being welded)
(Sorry, but your subject line got cut off.)
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
If you need further help, please reply back with your brand and model number so we can help you.
Jan 01, 2009 | Emerson Fans Emerson MW8115SS Microwave...
Fan & Turntable start when door is opened.
sounds like there is a switch that is bad. you can go buy a new MW for about 200$ and in yours if there is a major problem then i would just go buy a new one but might be worth a repair man to come check it out
pleas do not poke around in the microwave as it carries a charge of 5000volts and can kill you even if not plugged in DON'T TOUCH THE WIRES WITH BRAIDS ON THE OUT SIDE if you must get inside of the unit
Dec 10, 2008 | Microwave Ovens
Glass turntable
Dec 07, 2008 | Panasonic NN-H965 Microwave Oven
Microwave turntable
The solution is very simple. Unplug the microwave first. Remove the round dish. Remove the circular riing with the rollers and set aside with the dish. Carefully with a butter knife, pry up the coupler and set aside. Examine to make sure it isn't broken or cracked where it slips over the motor shaft. Remove 5 Phillip head screws from the bottom pan and it hinges down out of the way exposing the motor. Remove 2 screws holding the motor, slip off the plastic dual flat connector and slip back onto a new motor $52.25 + shipping from GE parts. Remember your actual MW Model number is NOT XL-1800 but it is on a metal tag inside the MW on the left side. Put the motor screw in as removed so the shaft is free to stick up the hole in the bottom of the MW. Put the pan screws back up, put the coupler on, the ring in and then the dish and line the slots of the dish up with the star coupler so it catches. Turn on MW, touch the turntable button and make sure it is "ON" and not "OFF" and it should be, with the door shut, turning like a quiet little top as new.
Aug 19, 2008 | Microwave Ovens
No heat - where is the diode
Sorry to answer so late in the game, but in case others have this problem, you can find helpful exploded view diagrams and order parts by entering your model number here:
Aug 23, 2007 | GE JVM1640 Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
108 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
