Question about Motorola Mobility H700 Wireless Headset
Help i deleted my motorola H700 headset from my palm treo and I lost my paperwork on my headset can you help please?
  • Daisey88 Nov 10, 2007
    I cannot pair my Motorola H700 wireless headset to my Palm Centro. I turned on Blue Tooth and I held down the button on the headset for 5 seconds. Nothing happens. I would appreciate any help I can get.
    Thanks, Joann
By Guest
Rank: Not rated
Rating: 0%, 0 votes
First, turn on your bluetooth on your phone.
Flip the boom mic on your H700 and hold down the call button for 5 seconds.
The indicator light should be purple. That means it is in pairing mode.
Then using your phone, attempt to connect to your H700.
It'll ask for a passkey. The default passkey is 0000.
Posted on Nov 10, 2007
How to pair motorola H700 wireless Headset with my treo 650
Open the headset boom: it will flash steadily purple, it it's not paired ever. If it was paired turn that devices off; open the headset boom, blue will steadily lit; after 5 seconds, it will steadily purple lit. Now find Motorola H700 on bluetooth and type password: 0000. Done!
Dec 18, 2010 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Need to pair my h700 to my palm treo what to do?
Hello, here's a link that give's step by step instructions on pairing your device to your phone,
Mar 29, 2009 | Motorola Mobility H700 Wireless Headset
I have a Mac laptop, a Palm Treo Wx and am now using a Motorola H700. I need to know how to sync my H700 with my Treo so I can dial via my headset and not need to use the actual cell phone. It has now...
Hi, i'm not sure what the Mac has to do with your Headset. You can register your blue tooth headset with any device that supports bluetooth. In fact, you can use your headset with multiple devices. Even your Mac can use bluetooth to connect to a headset (if you have bluetooth turned on, and not all Macs have factory bluetooth).
To 'register' your headset with the Treo is a two step process.
on the Treo, make sure bluetooth connectivity is turned on, then you should have a menu that allows you to find/enroll a new bluetooth device. Before you tell it to find a bluetooth device, turn on your headset. Now tell the Treo to search for devices. If it doesn't find your headset, then press and hold the button on the side and it will send out signals that your Treo will see. The Treo might give you a password code and ask you to confirm this is the device you want to synch to. Usually '0000', but in any case say yes, so long nobody else is around trying to do the same thing you are within 30'.
That should do it.
I don't think the Treo has voice recognition, which makes dialing on my Nokia a breeze, for true hands-free operation, nothing beats it.
Also note, the Treo has been know to have issues loosing bluetooth connectivity with the headset and not reconnecting with a re-boot.
so long you keep the two devices near each other, this shouldn't be a problem.
Jul 05, 2008 | Palm Treo 700w Smartphone
It's paired up with treo, but when treo rings, the headset will not work.
there are known compatability issues with palm treo and blackberry phones when trying to use this type of headset .
I recomend a Plantronics brand headset with your phone.
Nov 17, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 wont sync with my Palm Treo phone? When I first got it the phone and headset worked fine but I think i am missing a step when trying to sync. The phone is fully charged The headset if...
Did the headset become unpaired with he phone? If so make sure the boom is closed and Hold down the button on the side until it starts to blink then run the wizard
Aug 03, 2007 | Motorola Mobility H700 Headset
Motorola Mobility H700 Wireless Headset Logo
79 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
