Question about Yamaha 12V Air Pump
The thing was running fine, I ran it completely out of gas out on the lake, reserve and all. I did try to start it a few times to get me a little closer to where I needed to load up at. Loaded it, went and got gas, put it back in the water made it almost all the way back to my dock and it died. Now it will start but won't really stay running, changed the plugs, check the carb, everything looks good. There is a little bit of water inside and it is not blowing the rooster tail when you start it. Any ideas on what you might think it is?
    Champion:
  • 207 Answers
You pulled the diaphrams in the carbs and sterched them from running it out of gas or sucked water in to it either way change the carb kits
Posted on Jul 08, 2009
Car ran out opf gas , put gas in , it turns over but wont start
Fuel pump or relay most likely pump make an model would help to know
Oct 06, 2015 | 2003 Oldsmobile Alero
My 2001 isuzu rodeo ran out of gas and when I put more gas in it, it didnt want to start. It finally did and I drove it a few miles and now it wont start at all. It back fires very loud and dies.
Fuel is what lubs the pump you might have burn it cranking it without gas if no fuel n you keep cranking it it will burn its inside the tank
Sep 10, 2015 | Isuzu Cars & Trucks
Ran completely out of gas last week - put gas in - car started fine- ran a little rough and idled rough. Now 10 days later MIL light on in dash and perform service message. Won't go out after several
have the fuel filter changed and have the computer checked for codes incase something else is going on and they can be cleared to turn off the light.any dirt in the lines should be out of them by now.its possible that there is dirt in the injectors and a fuel system service should be done to clean them which is a recomended service on all cars anyways.you can have the fuel pressure checked while its in the shop to make sure the pressure is within specs.
Nov 01, 2011 | 2004 Jeep Grand Cherokee
I have a 1998 Dodge Caravan. I got a "tune up" approx. 2 weeks ago with new spark plugs, fuel filter & air filter. It did fine driving around town & on a 130 mile trip. I filled up with...
Sounds like you got a tank of bad gas. That would easily cause your issues. Start by draining as much as you can, put a can of Seafoam in there, add a few gallons of fresh gas, drive to the gas station and tank up, and run that tank down until your gas light comes on before adding more. You may end up needing a fuel filter or plugs again, but with minimal run time on the bad gas, you'll probably be fine.
Jul 29, 2011 | Dodge Caravan Cars & Trucks
I ran out of gas in my car, so I put $5 gas in the car and it didn't start, so I added another $5 gas in in again and it still won't start, we tried boosting it and it won't start so i don't know what is...
Dont touch the gas pedal or it might flood and not start. Have someone spray a little starting fluid in the Air filter tube while you try to start it.
Jan 17, 2011 | 2005 Pontiac Grand Prix
Car has set for a year, but was working fine before it began to sit. Now when I try to start it it wont start. Changed the battery and sprayed starter fluid in the carburetor, it started for a moment then...
This may be a fuel injected engine. On some vechicles when they run out of gas you have to turn the key, but not try to start the car. Give it a few seconds for the gas to feed back through the gas line. Once you turn the key, the fuel pump will start pumping the gas to the engine for the carburator. If that does not work, then give it a little gas, no too much or you could flood the carburator. Try to start the car again.
Nov 27, 2010 | 1999 Lincoln Continental
Ran out of gas, now wont start
if it was out of gas completely, after filling with at least 5 gal, turn key on, without starting. You will hear pump come on. After pump stops, turn key off. Repeat this procedure three times an the engine should start after the third time.
Let me know,
Chip
May 31, 2010 | 2001 Chrysler PT Cruiser
Wont start now, idled last year but died when throttled up.
sounds like you blew some junk up into the carbs or injectors whatever the casse maybe. if you can try to blow some air through system or get a good cleaner and run it through the system, if its not too bad that should take care of it. These dont like running out of gas, try not to do so in the future. 1 more thing, sometimes a blast or two of ether will help also. Good luck
Jun 17, 2009 | Yamaha 12V Air Pump
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
Ran it out of gas,,now it won't start every time.
bleed your fuel rail .when it run out of gas air gets trapped inthe fuel system.
Oct 25, 2008 | 2001 Chevrolet Camaro
Yamaha 12V Air Pump Logo
161 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
