Question about Rockford Fosgate P3001 Car Audio Amplifier
Amp turns on but doesnt power my subs
Ok the p3001 turns on, it powers the speakers but it is VERY low, i have to turn it up ALOT just to hear a little thump, when i first got the amp it wasnt like this is played fine, after a while it just did that by itself, i have another amp hooked up to another set up 12s and that amp works fine, its just the rockford thats acting this way, i checked all the connections, re wired my subs, everything, is it something internal? and is it fixable?
  • 1 more comment
  • mrinfamouz Nov 07, 2007
    oh and yes i have the gain turned up all the knobs in correct places, its not anything of that sort, i tweeked all the knobs myself when i first got the set up and have not messed with them, i even double checked them as i was checking all the connections, i believe it is internal
  • mrinfamouz Nov 08, 2007
    "FREQ" knob
    "GAIN" knob
    and the LP-AP-HP switch
    FREQ and GAIN are set all the way up, since my subs are 150 rms each the 300 watt AMP shouldnt have a problem pushing them, they worked really grey for about 6 months, then it just got real quiet, i didnt really notice until i re wired my subs, because i was bridging the subs inside the box so i could connect all four to a JL 500/1, but i dont have the JL amp yet and i wanna know if this rockford amp is trash or if its fixable!
  • mrinfamouz Nov 12, 2007
    i dont think its the subs because when i hook them up to my other amp they play just fine! maybe its my amp connections, but ive checked them atleast 3 times already, i guess ill go out and check one more time, you dont think its something inside the amp itself? i opened her up to check it out but i didnt know wat i was looking at,, and no i live in north virginia!
  • 3 Answers
Well ill need 2 know wat knobs are all on the front of your amp
Posted on Nov 07, 2007
  • playaboy Nov 10, 2007
    well everything is fixable it could be that ur subs are connected wrong meaning they are cancelling each other out does ur amp get hot and do u live in cape town
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
I just installed a new xo vision x349nt dvd receiver in my car . My rockford fosgate p3001 amp turns on but the subs doesnt come on but when i would take the base control out and put it back in i can hear...
Make sure and check the RCA wires in the back of your radio that send audio to the amp and make sure that they're connected to the OUTPUT/SUBS RCA's and not an input rca's. Also, check your ground and make sure no speaker wires in the subs are shorted. Try one speaker at a time see if that helps.
May 18, 2011 | Rockford Fosgate P3001 Car Audio Amplifier
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
I have a few problems. i have 2 amps and 4 subs. first problem is when i connect one amp to my speakers it just hisses and crackles. this never happened before. when i turn up the gain to try and get...
The first amp, sounds like there is straight power going through the gain instead of it being limited. The second amp...hook the other subs up to it and see if it sounds ok. If so, then the subs are messed up. If it sounds the same, make sure the subs are connected correctly.
Oct 21, 2009 | Car Audio & Video
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Stuck On Thermal Mode.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still remains in thermal protection, the amplifier likely has an internal fault and will need to be repaired.
Dec 28, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Legacy LA1020 Low Sound, No Bass
have you checked the amp? there should be a switch on it to alow you to change the input of the power, it could be that this is on very low, causing not alot of noise and base to be produced. it could also be the remote lead to your head unit or that it isnt earthed in the best of places. if the amp power is on then you can probably say its not the earth, try checking over the amp for a switch to turn up the input, if not check the user manual and look for amp settings.
cheers, adam
Nov 14, 2007 | Car Audio & Video
RF P3001 power problems
check your sub woofer connection if you have multiple subs the could be wired in a parallel or with has to many ohms that my cause it to not hit right and cause the amp to get really hot and cut in and out
Nov 15, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
P3001 amp may be fried
Check this out:
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate P3001 Car Audio Amplifier Logo
175 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
