Question about AEG B2100-4 Electric Single Oven
AEG B2100 Not heating up - light does not turn on
The oven fan is on constantly, not heating up at all and light does not come on. There is power as the clock is working. I have switch if off from the mains hoping it will reset when I turn it back. But when I switch it on, only the fan on top of the oven turns and the clock, other than this nothing else works. Can you suggest a solution pls.
Main selector switch may have burned contacts.
Posted on Feb 17, 2008
My zanussi electric cooker has heated up, gone bang and there is black ash all over inside
Sharon First turn off power on this oven or unplug it if you where useing the oven then that element went bad if it was the broiler then it is that one , very easy to fix and it is cheep also, with a flash light look at the elment for damage don't touch it unless the power is off , get back to me with the information like make model serial number and i will locate the element for you and you can buy it at the place if find it for you . good luck Frank
Dec 07, 2011 | AEG B2100-4 Electric Single Oven
I have an AEG Competence Single oven model B2100-1-w The oven is not reaching or holding temperature I have noticed the fan is not spinning
Hi steve sounds like your fan motor is faulty they are not very powerful any resistance in the bearings can stop it starting. oiling the bearings wont help you need to replace the motor also it will have damaged the element no air circulating it will of overheated. an overheated element usually lasts till xmas morning.
Nov 09, 2010 | AEG U3100-4 Electric Double Oven
Aeg 3050b oven not getting hot fan running and both lights on no heat even when turned to 275 degrees oven was working ok yesterday but seems to have gone all at once
Does the thermostat click and the light go off and on when you turn it up and down if so it is mechanically working.
Fan will run irrespective of element working
Either the element has failed or the connections to the element
Both require you to take the back off the machine to check them out
Jan 26, 2010 | AEG B2100-4 Electric Single Oven
My aeg oven is blowing out cold air
If the fan is working o/k, then you need to replace the oven element.
Please rate my solution.
Aug 12, 2009 | AEG B2100-4 Electric Single Oven
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
Aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Apr 20, 2008 | AEG B2100-4 Electric Single Oven
AEG Oven
try setting the clock, it may be automatic
Mar 22, 2008 | AEG B2100-4 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
AEG B2100-4 Electric Single Oven Logo
292 people viewed this question
Top AEG Ovens Experts
Sal De
Are you an AEG Oven Expert? Answer questions, earn points and help others
