Question about RIM BlackBerry 8700c Cellular Phone
How do you undo the num lock - RIM BlackBerry 8700c Cellular Phone
    Scholar:
  • 87 Answers
To turn NUM lock on, hold the *Shift* key and press the *Alt* key. · To turn NUM lock off, press the *Alt* key.
Posted on Nov 15, 2009
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
Tip
How to enable the NUM LOCK key for the logon screen
The status of the NUM LOCK key is specific for each user, and it is disabled by default. If you want the NUM LOCK key enabled for use before a user presses CTRL+ALT+DEL to log on (the logon desktop), you need to edit the registry. To enable NUM LOCK for the Logon desktop (shown when no user is logged on), use the steps below:
  • Click Start, Run and type regedit.exe
  • Navigate to the following location:
HKEY_USERS\.Default\Control Panel\Keyboard
  • Double-click the value InitialKeyboardIndicators
  • Set the value-data from 0 to 2
  • Close Regedit
To undo the above, change the InitialKeyboardIndicators value back to 0
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
My keyboard is typing numbers and characters instead of letters!
Sounds like you have num lock on. The Num lock key is usually the same as Scrlk but to select the Num lock you have to press and hold Shift then press NumLk/ScrLk. A light should light up to indicate the keypad is on/off.
Regards,
G33k
May 11, 2011 | IBM ThinkPad T30 2366 Notebook
When I press the "u"
Welcome to Fixya
This means the number pad is locked. All you need to do is to press and hold the Fn key then tap the numlock key once. This will disengaged the numlock.
Happy to serve you.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jan 21, 2011 | Computers & Internet
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
My dell latitude keyboard is showing a lock with a number nine how do I undo?
it is just a num lock indicator if you want to turn that light off just press num lock
Jan 27, 2010 | Dell Latitude D510 Notebook
Function keys
Hi you need to hold down the function key (FN) and press the number lock key (num lk). hope this helps
Jan 14, 2008 | Gateway MX6453 Notebook
RIM BlackBerry 8700c Cellular Phone Logo
1,022 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
