Question about Kitchen Appliances - Others
Sesam 200 garage door lift won't run anymore
HI I have a sesam 200 garagedoor opener/lift.Suddenly, it stopped working.I quickly switched, with the wall switch, between opening and closing and back again.The motor stopped, the lightbulb went broken, and after that the thing is almost dead.When I press the wall switch, I hear the power being applied to the motor for a few seconds, and then the power is switched off automatically (probably some safety mechanism).I have disassembled the motor, the motor runs free in its bearings, no damage on the gears.i don't know what the problem can be.Any suggestions?Thanks in advance.Alex
Blue Dog
  • 75 Answers
SOURCE: garage door stops and reverses either way-up or down-
If the light on the opener flashes when this happens, count the flashes (which indicate the type of problem) and consult your owners manual.  If you don't have the owners manual, you can find a digital copy online at the manufacturer's website. Also, check your manual for an adjustment that tells the opener how much resistance you want it to tolerate before reversing.
Posted on Dec 22, 2008
  • 63 Answers
SOURCE: Ice maker is switching itself to clean mode
hi my name is mark, sounds like the clean switch is sticking. does this unit have a membrane in front of switch. switch might be wet. also you might let the clean time out, then restart unit.
Posted on Mar 10, 2009
  • 20 Answers
SOURCE: i am locked out of my garage
Pull the emergency release red handle down and back (toward the opener). The door can then be raised and lowered manually as often as necessary.
Posted on Jul 08, 2009
  • 3197 Answers
SOURCE: sesam 200 garagedoor opener/lift will not run anymore
Originally posted July 2, I doubt he is still here waiting.
Posted on Aug 08, 2009
  • 3600 Answers
SOURCE: Door locked on safe
Brian We can't give advise on the safe but you can call the manufacture of the safe and if you have registered it they will help you otherwise federal law requires a lock smith to identify you and your information and your ownership of the safe before they will unlock it for you. This is to protect you or the safe owner and the lock smith from being sued and losing his licence.. There should be a sticker on the safe with a 800 number for you to call to get help. But you must have registered it first. They may have a way to verify it some other way but am not sure.
Posted on Nov 22, 2009
My neighbor's 2008 Camry is suddenly opening and closing my Craftsman garage door opener. He lives about 200 yards from me. How do we get it to stop? Thanks.
You did not post the model of the opener but there should be a set of switches that are very small and you use those to set the encoder frequency on both the remote and the opener.
Dec 31, 2016 | Building Materials
Garagedoor opener fixed on wall will will open and close door. but will not work from the remote. problem my be because little green light flashing permanently. what is solution
Your opener is in the lock mode. Press and hold the lock button on the wall control for 3 seconds. This should stop the flashing of the light.
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garagedoor intermittantly will not close. moves one or two inches, stops, then backs up. other times it works fine. when it fails to close, I unhook, manually close the door, rehook by pressing the power...
If the main light is flashing 10 times when the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is not flickering ever so slightly. This will cause an intermittent problem like you have. Tweak the sensors just a bit.
If the main light is not flashing 10 times you may just need to increase the 'down force' just a tad. This control is on the rear of the motor unit near where all those white wires go.
Mar 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Nov 07, 2009 | Chamberlain 1/2-HP Whisper Drive Belt...
Sesam 200 garagedoor opener/lift will not run anymore
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor hums but nothing happens
I just had the same problem. Extreme cold, garage door stops working, motor hums, same here. I opened up the my garage door opener(after unplugging it), and found that the wormwheel had a wear spot on it. This is the gear that allows the motor to raise and lower the garage door. Any way, after the wife "sugested" that the door was too heavy to lift, I went and bought a new garage door lifter. But if you are handy dandy with tools, I have seen the wormwheel for sale here. http://www.aaaremotes.com/gearsprocask.html It's the plastic wheel that went bad on me. If I would have found this before buying the garage door opener, I would have got the sprocket assembly. I hope this helps!
Jan 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Appliances - Others Logo
189 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
