Blockclogs easily if you get some water in the diesel.age in fuel system. Remove both pipes from tank to pump and blow. If clogged replace. Also check fuel filter. That thing
Yes, it is quite easy. These bushings are a very common source of rear end rattles. Remove the bushing retainers, replace the bushing, and then the retainers and bolts. Torque is low, 14 ft-lb
The rear drum bushing or the front drum slides (or both) are probably worn out. You can view the rear drum bushing by removing the small plate in the center of the rear panel. Check if the center pin on the drum is touching the rear drum bushing housing. The rear bushing is made of plastic and is only about 1/16" thick, so look closely. If the loud noise is metal on metal at the rear drum bushing, replace the whole rear bushing assembly (drum center pin, bushing, and housing). Often, the front drum slides also need to be replaced. Check them before you buy the rear bushing. There are two at the bottom front of the drum and four more at the top front of the drum. You'll have to remove the front panel to check them.
