Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Saeco Vienna gear jammed
Gear won't re-set -- even with instructions from Saecco about starting the machine without the brew group inside. Brew group won't fit back in b/c the gear is out of place!
  • mount-n-due Nov 12, 2007
    cant reasemble because of gear position
  • cliffh Dec 09, 2007
    Cleaned system out completely, checked gears and all looks okay BUT I still get that clanking noise everytime I try to start it.
  • 3 Answers
If the machine is simply "out of sync" with the brew group, do like this. With the brew group removed, and the front door open, insert two thin objects in the small slots to fool the machine that the brew group is inserted and the door is closed. The machine performs a self test (you can see the drive gear spin. Once the machine is done, the drive gear has been reset to the start position. Now, focus your attention on the brew group. It also has to be set to the start position before inserted into the machine. There are two small arrows on the back. Move the parts in the brew group until they align. Now the brew group is ready to be inserted into the machine. If you still get a noise when you restart the machine (a banging noise at some point during the self test) it probably means that your drive gears needs to be replaced. ine had 3 missing teeth on the big one, and 1 mission on the small one. No big deal, a new set costs around $12 on eBay. You need to disassemble your coffee machine, but it can be done easily with a Philips head screw driver and a torx bit. I did it in 20 minutes without any instructions - you can do it too.
Posted on Oct 04, 2013
  • polestarjapa Oct 06, 2013
    "ine had 3 missing teeth on the big one, and 1 mission on the small one " should say "Mine had 3 missing teeth on the big one, and 1 missing on the small one. "
  • Anonymous Mar 15, 2016
    Really, it's that easy? Have to take the whole thing out, right? And pull connections and such? Hate to take it apart and not get it back together...scary.
This has happened to me. If the problem is the brew group gear is in the wrong position, you can manipulate the brew group until it matches up with the drive gear in the machine. You'll know it matches if you can insert the brew group back in the machine full until it clicks.
Posted on Dec 08, 2007
Saeco Vienna - I turned on the coffee machine and instead of the usual whirling of the parts getting into place, it sounds like it is struggling to get into place. I looked inside and the bar is down where...
Hi Its hard to say with what you have said, but if the brew unit was cycling slowly, it may be the board. Close the door and make sure that everything is in but the brew unit. Turn the machine on and see if it cycles the gear in back to the starting point. It may take a few minutes to cycle if its the board. If it returns its the board. I have some boards.
Jun 13, 2011 | Saeco Vienna Espresso Machine
The brew group to my Vienna Deluxe is out of sync. I cannot get it to fit into the machine and then add the dump box for the grains. They do not fit. I do not want to force the brew group into place....
Problem: Brew group is out of sync. Brew group insertion. Brew group alignment.
Answer: Common to all Saeco superautomatics. After removing and cleaning the brew group, it will get onto the supports but will not lock into place as the gear is not aligned. With the brew group on a clean, well lit table, use a pair of chopsticks and a friend to assist. There is a small lever arm on each side that is accessible from the outside of the brew group. As the carriage slides down towards the correct position, the arms are seen 1" above the drive gear and towards the handle side of the brew group. Gently push in the lever so it slides inside of the locking bar. Both sides need to get pushed in at the same time so it helps to have a friend hold the brew group and push in one side while you pull down on the carriage and push in the other lever. The chopsticks insert into the half-moon on each side above the locking mechanism.
Jul 31, 2009 | Coffee Makers & Espresso Machines
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Apr 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Long time for drip coffee.
Grinder is set to too fine. Lower grinder settings. Keeping the machine at current settings with drip extraction will result in brew group clogging, gear stripping, and/or dulling of grinder burrs.
Jan 30, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna deluxe brew group was jammed
If you have the box the machine came in there is a key that kinda looks like a wine opener, use that to set the little arrow on the brew unit to the "N" letter, then the unit will fit into the machine.
Dec 26, 2008 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna Digital Expresso Maker - brew group will not line up to fit back into espresso machine
Could be a number of reasons. If you "hear" the brew group moving in one direction, stop and then move again, then the microswitches are o.k. If the sound of the movement is low and/or slow ( slower that normal), the CPU/power board may be bad and needs to be replace. If the movement is as before (same sound and movement) but not lining up, perhaps the brew drive motor is bad.
To remedy this situation, an authorized SAECO Service Center would have to open your machine and replace damaged components. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Feb 18, 2008 | Saeco Vienna Digital Coffee Maker,...
Saeco stopped working during process
jammed brew unit, possibly also damaged gears.
Do not keep turning the unit on at this point, cuz it can damage it even further.
Has to be sent out for service, be sure to tell them to check gear system and mention jammed brew drive.
Aug 23, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
1,066 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
