Question about Dometic Rooftop RV Air Conditioner
With thermostat in the off position compressor continues to cycle continuously every 5 minutes for 1 minute. Is this normal operation for the unit??
  • 37 Answers
Yes it is a normal operation
dont worry
Posted on Jun 29, 2009
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
The thermostat is set to off. The compressor keeps kicking on. Need help asap, camping now.
If the compressor is constantly running and not cycling off then the contactor is stuck in the closed position. If the compressor is cycling on and off and on again then there is a short in the low voltage circuit. Could be anything from the t-stat to the control wires. Normally the contactor points will stick closed and the outdoor unit will continue to operate with the t-stat in the off position(or any position). The contactor is the only part on the o.d. unit where the main line voltage wires connect to the unit. There is 1 moving part in the center that may be stuck closed. Turn off power at the breaker or disconnect box at o.d. unit. If this unit cools without the indoor unit operating it will freeze up, allowing the compressor or to remain at the indoor coil and it may/WILL damage the compressor. Call a technician!!!
Jun 13, 2015 | Heating & Cooling
On my 2004 Grand Prix, my car has to be running for at least 45 minutes for some heat to work.The yellow light by the heater blinks while the blower comes on and goes off repeatedly until the light is...
It is possible that your thermostat is stuck open. Normally, the thermostat remains closed when starting cold, confining coolant to the engine block and cylinder head until it heats up. Once the coolant in the block is warm (usually within 10 minutes), the thermostat begins to open and let coolant flow into the radiator to cool it down some. A properly operating thermostat will continue to cycle until the coolant reaches the operating temperature of the thermostat--usually around 180 deg F. Then the thermostat will continue to adjust its opening to maintain that temp.
Thermostats can get stuck in both closed and open positions. When stuck closed, the engine will quickly overheat. When stuck open, the engine will take forever to warm up--especially in cold weather because the coolant is continually pushed into the radiator and cooled off before it ever has a chance to get warm. Changing the inexpensive thermostat may help correct your condition.
Jan 25, 2011 | 2004 Pontiac Grand Prix
OUR REFRIGERATOR RUNS ALL THE TIME AND ONLY SHUTS OFF FOR ABOUT 5 MINUTES A DAY. ALL THE FOOD STAY COLD AND FROZEN IN THE FREEZER. REFG.
Most of the time when a unit runs all of the time there is a problem with the evaporator fan being either blocked with ice or running slow due to a dirty bearing. The 5 minutes a day you are refering too is the time when the defrost cycle is in progress. If the defrost cycle is working properly is should take more than 5 minutes. I would try manually defrosting the unit by unplugging the uint, removing all the contents of the freezer and place a fan so that it blows into the freezer section for about 2 hours. This will melt the ice if any in the freezer section and clear any ice blockage. Mind you this will result in water dripping in places that it normally does not drip so have a mop and rags available to tend to the dripping water.
After the 2 hour period plug in the unit and re-load the freezer. If the problem is corrected by maually removing the ice with the fan then you of course need to do nothing more. If the unit after a serveral days begins running all the time again then it is not defrosting properly. Just reading your 5 minutes a day off time has me thinking that the defrost thermostat has failed in the closed position causing the defrost timer to cycle straight through the defrost cycle vs pausing until the termostat reaches 60 F an closes as it should in normal operation. If that thermostat is closed all of the time there will only be a very short pause 3 to 4 times a day whent he compressor is off. This is not an expensive repair should the uint require further servicing after you manually defrost it. Good Luck.
Jan 04, 2010 | Refrigerators
The unit cycles every minute and the fan continues to run.
you are right the problem is with the thermostat. if this is an all-in-one unit there is a wire that runs from the thermostat to the front of the evaporator coil where the air returns to the system to be cooled. you can try to move the wire further away from the coils and see if it prevents the unit from short-cycling. btw it's not very good for the unit to do what its doing now, as i'm sure you could imagine. if its a separate thermostat i.e. one that runs on 24V and has wires running to the a/c, then just replace it with one from Home Depot and you should be good to go. if it's other than 24V then you will likely have to get a replacement thru the a/c's manufacturer.
Jun 16, 2009 | Dometic Rooftop RV Air Conditioner
After cleaning coils and in back of fridge, it appears that the defrost keeps cycling every 5 minutes
hi
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Oct 10, 2008 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Motor never turns itself off
If by motor you mean the compressor itself then no, it should not run all the time. The compressor should run until the thermostat senses the temp. is at where you set it then turns off the compressor. A couple of possible things... if the unit has a leak in the refrigerant then it may run almost continuously since it can barely reach the cold setting you have selected. Or the temp. sensor thermostat may be bad and the unit doesn't know to turn off. There is also a defrost cycle that happens about every 12 hours for a few minutes (depending on make/model on how it works) but that should also turn off the compressor and fans until the defrost cycle is completed. Basically it should turn off when the temp. setpoint is reached or when it's in the defrost cycle.
Jan 14, 2007 | Admiral 26 cu. ft. Side-By-Side...
Dometic Rooftop RV Air Conditioner Logo
66 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
