Question about Sony Playstation 3 (PS3) Console
Ps3 headset i scanned and registered my headset but cant use it. is there something else i need to do it?
  • 66 Answers
Try charging it i had the same problem with my Motorola one and it wouldn't but if you charge it and go to accessory options you need to input the device your using their should be two lines saying the name of the Device.
Posted on Jun 29, 2009
How do you connect to the ps3?
*NB: it will ONLY work for communications, NOT for game audio. (lame az, I know!)
  1. hold in the headset's power-on button until it flashes red/blue for pairing.
  2. Next make the ps3 scan: settings> accessories settings> manage bluetooth devices> register device (yes)> scan and add. (probably passkey 0000)
How to connect any Bluetooth headset to your PS3
Dec 25, 2013 | Creative WP-350 Headset
Kindly help me connect my samsung HM1100 bluetooth headset to my playstation 3
1) Go to "Settings" on your PS3.
2) Scroll down and select "Accessory Settings."
3) Select "Manage Bluetooth Devices."
4) Select "Yes" when the message "The Bluetooth device has not been registered. Do you want to register?" is displayed.
5)
Turn on your Bluetooth headset when asked by the message "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, check the instructions supplied with the Bluetooth device." While each Bluetooth headset is different, for most this means to hold down the power button until the blue light on the device remains solidly lit.
6)
Select "Start Scanning" once your Bluetooth headset is in "pair" mode. Wait for the PS3 to scan for your Bluetooth headset. If the scan was successful, your Bluetooth headset will be listed on-screen. Select your headset from the list
7) Refer to the Bluetooth headset's instruction manual to find the pass key for your device (Usually the pass key is something simple like "0000" or "1234". Press "X" to bring up the on-screen keyboard and enter the pass key. Select "Enter" then "OK." "Register Completed" will display to confirm a successful connection.
NOTE: If the headset does not display after a scan, it may not be compatible with the PS3, or it is not properly set to "pair" mode. Refer to your Bluetooth headset instruction manual for directions to properly set your device to "pair mode."
If you want to check the User Manual for your Bluetooth, simply click on the following link:
http://www.samsung.com/us/support/downloads/BHM1100NBACSTA Click on the Icon below "File" Thank you.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
How do i sync my mad catz blue tooth headset to my ps3?
You'll need your controller, console, and headset to do this. Make sure your headset is off before you start, then follow these simple steps.
  1. Power on the PS3 console
  2. Within the "settings" menu, press X on "Accessory Settings"
  3. Press X on the icon labeled: "Register Bluetooth Device"
  4. Scroll down and press X on the icon labeled: "Register Headset/Microphone/Headphones"
  5. Prepare the headset to be paried by holding down the main buttong for 8 seconds.
  6. Once the LED flashes blue and red (indicatin the headset is ready to be paried), press X on "Start Scanning"
  7. Once Scan is complete, the PS3 will list all Bluetooth device visisble and within range.
  8. Locate your headset ID, most likely "8860" or something similar, and press X on it's icon.
  9. Enter 0000 (four zeros) as the Pass key and hit OK.
  10. Now enjoy your synced headset!
If any part of this confuses you, you can find the manual for your headset online here. You'll need a PDF reader to view the file. There are plenty of free ones on the web, but if you don't already have one, I'd recommend this one. It's free and simple.
Oct 05, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
I need the code
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Register Bluetooth® Device."
Headphones."
5. Once at the next screen, prepare the Headset to be paired with the
PS3 by holding down the K1 button for 8 seconds.
6. Once the Headset's LED indicator is alternately fl ashing Blue and
Red (indicating the Headset is ready to be paired), press X on "Start
Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices
within range.
8. Locate "8860" from the list of available devices and press X on its
icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register
completed"
If this does not work can I get the model # so I can get you more info
Good Luck an d rate 4 thumbs up for the free answer.
Sep 25, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do you turn the bluetooth on on a ps3 cause i cant get my bluetooth headset to pair
Turn on your Playstation 3, and from the main menu go to Settings - Accessory Settings - Register Bluetooth Device
You will be presented with two options:
Register BD Remote Control
Select Register Headset... and put your Bluetooth headset into pairing mode. On your PS3 select Start Scanning
Select your device and enter your pairing code. In most cases for audio devices the default pairing code is "0000"
Now on your PS3, go to Audio Device Settings and change your "Input Device" and "Output Device" to your Bluetooth headset name. Try speaking and watch your "Mic Level" move!
This might help you as well:)
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=898874
Dec 22, 2009 | Sony PlayStation® 3 (80GB) Console
Trying to register device to ps3 but I don't think
Yo i have the same problem except with a Samsung WEP250. I Disabled and deleted it off of my phone. And Now it wont scan my ps3. It might be the bluetooth problem. Go back to the store and ask them what went wrong. I am going to do the same.
Jul 12, 2009 | Motorola Mobility H300 Wireless Headset
Registering bluetooth headset
try having it connected with the usb cable and being turned on
Mar 15, 2009 | Sony Playstation 3 (PS3) Console
Headset connection for ps3 bad company
ok mate go to settings press x and then go to bluetooth device ok then scroll down and press x on the icon labelled register headset ok next turn on your bluetooth device then when ya do sumtin will pop up on the screen and press x on start scanning and once the scan is complete the ps3 will recognize all bluetooth devices within the range hope it helps
Feb 18, 2009 | EA - Electronic Arts Battlefield Bad...
Ps3 bluetooth headset
You need to "pair" the headset to the PS3. Follow the instructions for your headset (usually holding down the power button until you get a SOLID blue light) then go to Settings>Accesory Settings>Register BlueTooth Device>Scan. When you're done, you need to set your input device to your Headset model #, which should now appear.
Feb 16, 2008 | Sony Playstation 3 (PS3) Console
Connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
Sep 25, 2007 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
