Question about Belkin (F5D72304F5D7000) Router
Belkin wireless g router wont turn on
My Belking wireless g router wont turn on. I just bought it about 2 weeks ago and it was working fine until one day i unplugged it, now the little sucker wont turn back on when i plug it back in.
  • 193 Answers
Re: Belkin wireless g router wont turn on
Check weather the power adpter making issues>and check with surge and power stripe and try connecting directly to the wall scores still if its not on replace teh power adapter or replace the device i think u have warreny so u will not get charged>rate me solved if its helps thx
Posted on Nov 08, 2007
0 characters
3 Points
Bought router in 2009 and worked fine up until about a month ago. Every couple of minutes will disconnect. Wireless connect on laptop shows it is connected. I get page not found. Soon as I unplug it...
try updating the firmware to the latest version.
it may fix any bugs or wireless issues in the update.
Apr 05, 2011 | Belkin F5D8236-4 Router
I had to reset my router because I forgot my security key. Now the wireless isn't working. The light is off and I can't connect to it with my laptops. What happened and how can I fix it?
It is possible that since your reset your router that the settings is more likely to be reset as well then you will have to connect using an ethernet cable direcly from the lptop to your router to turn on the wireless capability of your Belkin router.
You will need to get your router's Default gateway to get in the router and turne the wireless capability on it. Most probobly the IP address of your Belking would be type this in IE on the address bar then press enter this should lead you into the router "Belkin" make sure that your are connected using ethernet from the laptop to your Belking router to be able to do this.
Feb 21, 2011 | Belkin (F6D42304) Wireless Router
Windows 7 upgrade, Belkin wireless router. Sa...
I RECOMMEND YOU TO UPDATE THE FIRMWARE OF YOUR ROUTER. Download the firmware from belking support site.
May 20, 2010 | Belkin F5D8236-4 Router
Not getting wireless connection
Unfortunately Not All the details are not given in this
Any way
Try This
Open RSP By typing on the Address Bar of Internet Explorer
On the Left hand side underneath Wireless Click Wi Fi Protected Setup
Leave the Password Blank and click Submit
Disable it And Apply Changes
Jan 06, 2010 | Belkin F5D8236-4 Router
I have a Belkin G wireless router and everything was working great until last night. Now if I run my wired laptop through it I can't connect nor am I picking up a wireless connection. I have uplugged and...
Thisis a common problem I have with Belking Wireless G and find the best solution is to remove the software and of the course reboot then reinstall.
Dec 10, 2009 | Belkin Routers
Password on my belking
ya want to put password on my belkin
Feb 28, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
We've just moved house and have aquired to belking routers a belkin wireless pre n and a belkin ADSL G Plus MIMO I want to use the latter as a bridge how can I?
You need to access the setup page of your Belking router and go to the wireless setup, look fro Use as Access Point, now just a reminder this will defeat the NAT IP sharing feature of the router. Configure the IP address of the router to the same subnet as the network your tying to bridge here's the more detailed procedure:
1. Enable the AP mode by selecting "Enable" in the Use Access Point only page. When you select this option you can now change the IP Settings.
2. Set your IP settings to match your network. Click "Apply Changes"
3. Connect a cable from the LAN port of the router to your existing network.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
check you cable connections, try to check if you can go online wired to the router if you are connecting wirelessly. You can also bypass the router and connect directly to the modem to make sure its working.
Jun 15, 2008 | Belkin (F5D7230-4) Router (587009)
My Belkin Software!
Try the Belkin WEB site or Google the driver
May 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D72304F5D7000) Router Logo
4,551 people viewed this question
Top Belkin Routers Experts
 C. Dante
C. Dante
steve morris
steve morris
Are you a Belkin Router Expert? Answer questions, earn points and help others
