Question about Toshiba Satellite A135-S4527 Notebook
Power indicator and battery lights come on when computer is plugged in. However, after a few secs. the battery light will go off for a sec. come back on for a few then go off and stay off. The power cord has been tested and is working. Also, the battery was removed and the computer tested with only power cord connected. The computer would not power up. Do I have an internal power problem??? I am running out of options. Thanks Britt
  • 54 Answers
Most computer systems will not run without the battery in. and it sounds like the battery might be bad.
Posted on Jun 29, 2009
Blue light flashing
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
Apr 16, 2014 | Belkin Computers & Internet
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
May 13, 2010 | Dell Latitude 100L Notebook
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
My acer aspire turns on for a second then powers down. I have taken the battery out and just used the power adapter but same problem. The hard drive indicator light and the power light both come on for...
Bad battery damages the power suplly and the plug. Check to see if the pin in the power socket (in the computer is loose) Common problem in laptops. The socket may need replacing.
Jan 24, 2010 | Acer Computers & Internet
I HAVE A GATEWAY 7320GZ.IT HAS ISSUES!!!!!!!!WHEN I TURN IT ON IT START 2 BOOT UP,BUT ABOUT 2 OR 3 SEC LATER THE POWER LIGHT STARTS 2 PLINK AND IT JUST POWERS DOWN ALL THE WAY.THIS IS WITH THE POWER CORD...
Hello, you can reset the battery, battery off, after 45 second push down the power botton for 5 secund and release,then put it back the battery and try turn on ,if don't working,you can try follow this link to change the battery.
Amazon com Gateway 7320gz Laptop Replacement AC Power Adapter Includes...
Jun 09, 2017 | Gateway 7320GZ Notebook
02 VW Jetta TDI with ALH engine glow plug
this is a common problem for these cars glow plugs go bad like spark plugs however the smoke would lead to bad mass airflow meter. it is not telling ecu corrcet miss. disconnect mass airflow meter. when cold see if this makes it start better. it should would means you need new m.a.f. glow plug issue take a test light place clamp on positive of battery then pull off glow plug connectors place tip of test light on glow plug the bad one will have a dull light unlike the good one which will be brighter. will need new plugs and wire harness four **** connectors and wire striper and crimper will fix concern good luck
Sep 01, 2009 | 2002 Volkswagen Jetta TDI
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
Mar 16, 2008 | Dell Latitude D600 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
63 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
