Question about Hayward Pro Series 18" Above Ground Pool Sand Filter System with Pump
We have a hayward pump and the motor keeps stopping and tripping the circuit breaker. What could it be?
    Scholar:
  • 34 Answers
The motor might be too powerful for the line it's on, (usually a pump should be on a somewhat dedicated line) no Ac's running on same breaker.
An extension cord longer then 6ft is also a suspect in not allowing the pump the draw enough power.
The pump may not be drawing enough water, overheating and tripping the breaker, or the motor might have rust on the inside causing the armature not to spin freely, and shut off. (usually motor will make a high pitch noise) while running)
Posted on Jul 04, 2009
Vs pump trips breaker. single stage 1 1/2 pump works fine, does not trip
is motor getting hot if so need new motor also check to see if wires on the back of the motor are loose or the wires to the breaker loose if they are ok you need a new pump motor or pump sometimes a whole pump is cheaper than fixing the old one
Jun 01, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Replaced pool pump motor but breaker keeps tripping
Breakers are mechanical parts and can fail. If none of your components are causing the breaker to trip it's the breaker itself.
Nov 18, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
I have a newly installed pump (1 month old) it is tripping the breaker.
If your pool has a salt water chlorinator and the salt level is too high then it could trip the circuit breaker as the combined load from the salt water chlorinator and pump motor exceeds the circuit breaker rating.
Jun 12, 2012 | Hayward Pool & Spa
The pump was left off for a couple of weeks. When I try to turn it back on, the circuit breaker trips. I banged the pump housing with a rubber mallet bu it still trips the breaker. Thank you
You may have a blown motor start capacitor, or the motor shaft has seized up. Try to see if you can reach the impeller through the hole in the back of the pump pot and spin it with your finger. If you can't then it has seized and you will need to take it apart to see if something is jamming the impeller or the bearings are locked up. Make sure you have the power off before you try to spin the impeller with your finger or you could end up missing a finger if it should start running.
Sep 11, 2011 | Hayward ALADDIN GO-KIT1 FOR HAYWARD MAX...
Pump is tripping circuit breaker
If your pump is tripping the circuit breaker there is a very good change that the motor is bad. you can change the motor or purchase a complete new pump. I would pull the pump and take it to a local motor repair shop and have them check it for you.
Aug 29, 2011 | Hayward 3/4hp Super Pump Inground Pool...
When I turn on my pool pump (Hayward Super Pump), I see sparks and the circuit breaker gets tripped. What should I do?
replace the pump or have it rewound at a motor shop it will take about a week. it is bad and you cant fix it your self normally.
Jul 21, 2009 | Hayward 1 Hp Super Pump Inground Swimming...
Hayward Super Pump not turning on
it sounds like your pump is stack it could
bee that something is stack in the pump,
try somehow to turn the motor to see what is binding
get access thrue the pump.
G
May 18, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Hayward Pro Series 18" Above Ground Pool Sand Filter System with Pump Logo
500 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
