Is ther any kind of knocking or tapping noise comming from the cylinderhead? If not, you should be getting adequate oil being pumped up into there. So I would negate a bad oilpump and guess your pressure sending unit is faulty. Hope this helps.
IT CAN BE ANY OF THE ABOVE AND ALSO A DEFECTUVE OIL PRESSURE SENDER ON THE ENGINE, HAVE THE OIL PRESS TESTED WITH A MECHANICAL TEST GAUGE BY A SHOP, IF IT IS OK REPLACE THE SENDER FOR THE OIL PRESS LIGHT.
On dodge this issue is usually caused by oil leaking into oil pressure sending unit wiring plug from above. Lot of times unplug and clean with brake cleaner and fix oil leak
