SOURCE: Clutch pedal low near floor, can the clutch be adjusted?
hi the clutch on accent is hydraulic operation so if pedal is very low on disengaging clutch ? you may have a problem with the hydraulics 1st thing to check is fluid level? this is the reservoir that feeds both brakes and clutch but is seperaterated inside if fluid low? top up and bleed the slave cyl however if fluid low indicates a leak ? possibly slave cyl? if no loss of fluid ? then prob may be fault in the master cyl ? check fluid come back with any update please ps if this problem has just occured? check for leaks ?
