Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
I'm trying to find a check valve for a Campbell Hausfels 5 hp 25 psi air compressure
  • yadayada
    yadayada May 11, 2010
    WE ARE NOT A PARTS SERVICE WE HAVE NO RESOURCES FOR THIS.
  • 6,927 Answers
Take ur valve off and go to NAPA and see if u can get a valve to plumb in place of the oringinal
Posted on Jun 29, 2009
My 5 hp campbell hausfeld model hl 7017 pumps up to pressure but when it drops the motor starts but the compressor wont turn the belt just slips until pressure drops off to about 30 psi
Your tank check valve is not closing properly. It's a valve on the tank where the air line from the pump head attaches, It allows air in but not back out of the tank through the pump. When the pressure swtich turns the motor off, valve on the pressure switch lets the air out of the head so the motor can restart without any pressure in the pump head when the pressure in the tank drops. On rare occasion, you can clean the check valve out and it'll work again, more often than not you have to replace it.
Nov 24, 2012 | Campbell Hausfeld Maxus 60 Gallon (Belt...
Safety valve releases on stroke of motor when it gets around 145 P.S.I. replaced safety valve and still the same. please help
IS this a 175 psi unit. What was the safety valve psi that was replaced. I recommend removing the heads and checking the valves. Suspect you will find one of them bad.If safety is past the hp head remove and check hp valves first. If safety is after lp head check it first. I have seen and lp valve break and pieces carry over to the hp side. So if lp valve bad you may want to inspect the hp side also. Good luck!
Jul 21, 2011 | Campbell Hausfeld Air Tools & Compressors
Can an air crompressor check valve be cleaned
Only on very rare occasions can a tank check valve be cleaned and still work. The main reason is air pressure is usually high enough inside the tank that when the check valve closes after the pump turns off it usually damages the valve or seat just enough that a leak forms. It is extremely hard to fix a valve or seat so they will seal up again. Without your specific model number I can't tell you which part number you need but most check valves cost $17 to $25 for these types of compressors.
May 04, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Too hot little cold
Very possible your condenser is extreemly dirty and is turning off on a high pressure cutout. suggest you clean out condenser with compressed air. Brushing is not enough. also, check if condenser fan(at the compressor) is working.
May 21, 2010 | LG Heat cool Window Air Conditioner
Unit builds to 25-30 psi then shuts off. You must
unhook the output line from the pump. run unit for 5 to 10 min. if no problem, check the tank valve at the end of you out put line, it screws into your tank. that valve must shut off at every down stroke of the piston, or air well flow back to the pump. will put an overload on the motor. good luck
Oct 16, 2009 | Campbell Hausfeld Air Tools & Compressors
I have a Husky model Y6010 air compressor.
First remove the valve using probably about a 1/2" wrench but make sure there is no pressure in the tank before you do so. check the cone and seal by loosening the valve by hand and check for debris. If there is no debris then the problem is either the pressure relief valve or weak pressure regulator but may also be a bad piston seal if it is a direct drive unit.
Apr 28, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
207 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
