Question about Samsung HT-DS1000 System
Once switched on, PROTECT appears on screeen and system turns off
The Micro Component Audio System is only 10 days old and has been used 10 times... Model MM-X8
    Sniper:
  • 70 Answers
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Posted on Jul 03, 2009
Can I use a turntable with the Yamaha MCR-040DG Micro Component System? There does not appear to be a standard auxiliary port to plug it in to.
You can register with Yamaha and download the manual.
http://usa.yamaha.com/products/audio-visual/hifi-systems/mcr-040__u/?mode=model
If your unidentified turntable does NOT need a phono preamp (*) you can adapt its cables and use the front panel PORTABLE input.
* If you DO need a Phono Preamp eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 13, 2011 | Yamaha MCR040DG Micro Component System...
I ended up with one piece of a Teac model CD-X8 MIcro Hi Fi System. you can see what the whole system looks like at http://www.amazon.com/Remanufactured-CD-X8-Wall-Mountable-System-Subwoofer/dp/B000B65GV6...
Yes - you have the sub-woofer. It is a powered sub-woofer with a built in amplifier for both itself and a pair of small satellite speakers. Frankly, given the low cost of the whole system it may not be worth selling on ebay due to the high shipping costs of such an item, but I imagine you could get $30 for it or so on local craigslist or something, assuming you have no use for a sub-woofer...
May 05, 2011 | Audio Players & Recorders
Can you give me technical specs for LCD TV TH-L32E3A. Thanks
The proof copy of the Owner's manual includes the specs for the TH-L32EA and is available from: http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation . Enter the model number under keywords and then click search (do not use the drop down menus).
Specifications
Power
Power rating AC 220 - 240 V, 50 / 60 Hz 0.33 A
Normal (Home) mode 42 W
Standby condition 0.2 W
Display
panel
Aspect Ratio 16:9
Visible screen size 80 cm (diagonal)
698 mm (W) × 393 mm (H)
Number of pixels 2,073,600 (1,920 (W) × 1,080 (H))
Sound
Speaker 160 mm × 42 mm × 2, 8 Ohms
Audio Output 20 W (10 W + 10 W )
Headphones M3 (3.5 mm) stereo mini Jack × 1
PC signals
VGA, SVGA, WVGA, XGA
SXGA, WXGA ······ (compressed)
Horizontal scanning frequency 31 - 69 kHz
Vertical scanning frequency 59 - 86 Hz
Receiving Systems /
Band name
PAL B/G Reception of Off air broadcasts
Digital TV 7 MHz VHF / UHF (Australia) free-to-air TV broadcast reception
PAL 60 Hz
M.NTSC
NTSC
Playback of NTSC tape from some PAL Video recorders (VCR)
Playback from M. NTSC Video recorders (VCR)
Playback from NTSC Video recorders (VCR)
Aerial - Rear Standard Belling & Lee connector
Operating Conditions Temperature : 0 °C - 35 °C
Humidity : 20 % - 80 % RH (non-condensing)
Connection Terminals
AV1
Input
AUDIO L - R RCA PIN Type × 2 0.5 V[rms]
VIDEO RCA PIN Type × 1 1.0 V[p-p] (75 Ohms)
COMPONENT Y 1.0 V[p-p] (including synchronisation)
PB/CB, PR/CR ±0.35 V[p-p]
AV2
Input
AV3
Input
Audio
Output AUDIO L - R RCA PIN Type × 2 0.5 V[rms] (high impedance)
Others
HDMI1 - 3
Input TYPE A Connectors • This TV supports "HDAVI control 5" function.
PC Input HIGH-DENSITY D-SUB 15PIN R / G / B: 0.7 V[p-p] (75 Ohms)
HD / VD: TTL Level 2.0 - 5.0 V[p-p] (high impedance)
DIGITAL
AUDIO OUT PCM / Dolby Digital, Fiber optic
Card slot SD Card slot × 1
USB 1/2 USB 2.0 TYPE A Connectors DC 5 V, Max. 500 mA
ETHERNET 10BASE-T / 100BASE-TX
Dimensions (W × H × D) 769 mm × 514 mm × 207 mm (With Pedestal)
769 mm × 480 mm × 75 mm (TV only)
Mass 11.0 k Net (With Pedestal)
9.5 k Net (TV only)
(See page 73 of the manual for the specs as a table - I used Proof 2)
I hope this helps.
Apr 20, 2011 | Panasonic Kitchen Appliances - Others
How to unlock cd drawer in JVC micro component system ux-gn6
Hi from Spain!
It's so easy! I hope I can help You.
You have to put in OFF Mode the music machine and when it will be off You have to press at the same time the STOP and EJECT bottom.
If You want LOCK the cd You have to do the same but with the Music Machine in ON Mode.
All the best
Jol Macana
Mar 08, 2011 | JVC UX-GN6 120 Watts Micro Component...
Model ELCHW402 40" LCD
The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
I hope this helps.
Dec 24, 2010 | Element Televison & Video
Micro hi fi component system sony cmt-ne5 / ne3 I
Hello
Check its sled motor. It is the motor that helps to spin the disc inside. If disc do not spin inside, check the voltage at the terminals of this motor. If it is alright, and comes near to 5VDC, the sled motor is damaged and have to be replaced. OK.
Dec 03, 2009 | Sony CMT-NE5 CD Shelf System
I have an MM-DG35I Samsung ''Personal Micro Component System'' and am having problems using it with my ipod nano: I don't have the system attached to a TV which means that if I want to play from my ipod, I...
Dear Seantennyson,
I have a question for you about the MM-dg35i
Is the dock integrated on the system? or is an external dock connected to the aux connectors?
Thanks in advance
Sep 14, 2009 | Samsung Audio Players & Recorders
WHERE CAN I FIND A CABLE THAT CONNECTS SUBWOOFER TO TUNER MODEL NO. CD-X8 TEAC
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Teac CD-X8 CD Shelf System
No sound while playing dvd/cd
sound muting circuitery prblem or sound swiching section problem can occure this type fault.sometimes it can be cd /dvd printed board problem.give it to qulifid technician .
nuwan.
Dec 12, 2007 | JVC FS-S77S DVD Micro Component Stereo...
Samsung HT-DS1000 System Logo
498 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
