Question about HP Pavilion zd8000 Notebook
Hp pavillion zd8000 monitor has 37 vertical lines
  • 2,229 Answers
Interesting that you counted them!
If you haven't tried to reinstall the video drivers, do that.
If that doesn't work, hook up an external monitor to see if the display is OK on that.
If it is, then your LCD screen has a problem and will need to be replaced.
Posted on Jun 29, 2009
I have virtical lines on lap top
Once you start to get vertical lines on your LCD screen, it's usually time for a new screen. I would check first by running an external monitor just to be sure it's not the video card.
May 19, 2010 | HP Pavilion zd8000 Notebook
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
Vertical multicolored lines appear. Sometimes there are couple of vertical white stips and vertical lines
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mainboard. Have it checked by a professional.
Oct 05, 2009 | HP Pavilion zd8000 Notebook
White vertical line on monitor screen
The vertical line is because the screen is going, it needs to be replaced fix the problem. Try searching on Ebay if your laptop isn't under warranty.
Aug 30, 2009 | HP Pavilion zd8000 Notebook
Same problem with my zd8000 HP Pavilion laptop
what has happened with your notebook is a simple wear factor. on the LCD screen there are ribbon cables witch join the main PCB controller head to the LCD laminated portion (what you see) have begun to wear. i have just recently replaced a screen because of the same issue. try gently flexing the the screen and see if the lines dissappear. next open the screen up, and check the cable running to the back of the screen take care as to not damage anything.
Aug 12, 2009 | HP Pavilion zd8000 Notebook
HP Pavillion zd8000 with less than full screen view
IF YOU GO TO START, CONTROL PANEL,DISPLAY, SETTINGS YOU SHOULD BE ABLE TO SELECT YOUR MONITOR THERE,GOOD LUCK MATE.
Jun 14, 2009 | Acer X193W LCD Monitor
HP Pavillion zd8000
Ok the lines on the moniter means it is a bad screen that must be replaced and battery not working could be a few things it may be a bad battery or bad charging circuit to test this you can try charging another battery in your laptop and if it works it was the battery if not it might be the charging circuit.
Dec 04, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
339 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
