Question about Little Giant 3e 12ny 1/15 Hp, 33 Lpm, 230v Oil Filled Small Submersible Pump, 3.7m Power Cord
Oil light goes on and off
I have a dodge neon 2000. every time i let the gas go the oil light goes on, and when i step on the gas the light dissapear.
    New Friend:
  • 13 Answers
After an oil change if this keeps up replace the oil pressure switch it may not be sending a good signal. You may need to use a good flush to clean out the oil galleys.
Posted on Jun 29, 2009
MY DODGE NEON 2005 MAKES A CLICKING NOISE, USES OIL LIKE YOU DO GAS AND OVER HEATS, IVE TAKEN TO CAR DEALERSHIP TO HAVE FIXED AND IT IS ONLY TEMP FIXED AND GOES RIGHT BACK TO THE OLD WAY.
It could be your timing belt .That would make it burn oil and the noise could be your valves hitting the pistons. Take the spark plugs out and see if they are black that will tele you if they are burning oil. The timing belt should be changed after 80,000 miles .
Mar 31, 2015 | 2005 Dodge Neon SE
How much will it cost to replace the oil pump in a 2005 dodge neon
An oil pump for a Dodge Ram 2010 3500 cost: $111.20!!!
In this age of high gas prices, drivers who care about gas consumption are taking an interest in the Dodge Neon and buying top quality parts. When contemplating sturdy build and long lasting performance you want a stylish car from Dodge. For hardworking quality and styling from a vehicle, car lovers can believe in Dodge.
If an issue develops or a component needs to be replaced, don\'t economize with a second-rate part. A Dodge Neon is worth genuine OEM and aftermarket parts to function at top efficiency. When you wisely choose a trustworthy, historic Dodge, there\'s no doubt you\'ll get superb style. For decades Dodge has engineered heavy-duty and reliable cars that car buyers can count on to get the job done. For eye-catching style with tons of power car enthusiast turn to Dodge for their sporty vehicle needs. To maintain the resale value and luxury you bought with your Dodge Neon, it\'s important to select only the most reliable high-value car parts. Frugal people just need a sensible vehicle like the Dodge Neon. The Dodge Neon is a vehicle engineered for high performance and it requires the best quality auto parts. Excellent horsepower and automotive performance are derived from great parts and accessories.
The Dodge Neon Oil Pan is fitted to the bottom of the motor and encloses the sump which retains oil as well as the oil pump. Your Dodge Neon Oil Pan is used as a receptacle for the oil. Your vehicle\'s Dodge Neon Oil Pan retains oil in reserve and is frequently made from steel or aluminum and has an oil pan gasket to stop leaks. Your car or truck\'s Dodge Neon Oil Pan is bolted on the underside of the car or truck and supports the oil pump unit. Dodge Neon Oil Pans are important to lubrication and if they are old, your car\'s motor will definitely sustain damage. The Dodge in your carport was made using care and skill; it should have replacement components of the same high level of value. One website which makes finding affordable parts easy is PartsGeek.
18256-01144165-1085557.jpgThey are available for the following Dodge Neon years: 2005, 2004, 2003, 2002, 2001, 2000, 1999, 1998, 1997, 1996, 1995, 05, 04, 03, 02, 01, 00, 99, 98, 97, 96, 95. This part is also sometimes called Dodge Neon Engine Pan.
We stock these Oil Pan brands for the Dodge Neon: Mopar, Dorman and Replacement.
Nov 19, 2011 | 2005 Dodge Neon
2000 Dodge Neon engine light on. Trip code
autozone will scan the engine light for free. start there
Nov 11, 2009 | 2000 Dodge Neon
OIL LIGHT PLUS FUSE INDICATOR
most important...have your oil pressure checked!  then worry about the small stuff by starting in the fuse boxes.
Mar 27, 2009 | 2000 Dodge Neon
2005 dodge neon light stays on
i have a 2003 dodge neon and mine does the same thing and i had the oil changed by the dealer, its full of oil as well, they put just a tad over in it and the light comes on and blinks for second then goes off and the only thing i do is let the oil go out on its own and get to the level its supose to be and once it gets to that it will stop, well it should but if you want to be sure have it checked out. i hope this helps you out, let me know if it does.
Mar 24, 2009 | 2005 Dodge Neon
Tick noise
if its a constintly ticking noise while driving sometimes it can go and fade away, this is due to your tappets or also lifters are worn out or not getting oil to them due to your oil pick up, and this will also give you the engine light and the engine light wil stay on all the time till the problem is fixed
Jul 02, 2008 | 2000 Dodge Neon
Little Giant 3e 12ny 1/15 Hp, 33 Lpm, 230v Oil Filled Small Submersible Pump, 3.7m Power Cord  Logo
Top Little Giant Garden Experts
Jim Goldsmith
Jim Goldsmith
Mike Squire
john h
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
