There should be two tanks under the hood on the passenger side, one should be marked engine coolant, the other washer fluid. Do NOT confuse one for the other. On the side of the ENGINE COOLANT tank there are marks, The lowest one(cold) or highest one (hot) you can check the coolant either cold or hot, fill to the correct line depending on whether the engine is cold( not running for several hours) or hot( you just got done driving it.)
SOURCE: fuse box diagram
www.edmonds.com for owner manuals online I also have a 2000 expedition and it is normally one of the coil packs is out if you have an autozone near you they will put it on the tester for free and that way you will know what is wrong and if it is the coil pack if you are standing in front of the truck looking at the engine this is how the cylinder location is on the passanger side back to the back of the engine is one thru four and on driverside is five thru eight so when they tell you which coil pack is bad you will know which one to replace and you can get just the boot and a new spring and replace that for around $6 to $8 then replacing the whole thing for around $65. try www.autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
SOURCE: small evap leak -- check engine need diagram in
there should be a vaccum hose diagram on the under side of the hood pertaining to the evap system, check and see. if not just google it, shouldnt be too difficult to find.
SOURCE: Wiring diagram to add trailer connectionTrailer
http://www.youtube.com/watch?v=EgajKpMgZpE
He installs it in the video.
SOURCE: need engine diagram serious 2 engine 3800
I did not find a single page for an engine diagram but this link should provide a serious of images of engine diagrams for a 1997 LaSabre
