Question about Maytag Neptune MAH7500WH Front Load Washer
My front loader washing machine will not spin or start a load. I turn it on and it wants to start but nothing happens. I put a blanket in the washing machine last night and it was very heavy and the cycle never finished do you think the drum is off balance now??
I have a MAH4000 washer it will not spin the water out, It fills and pumps out the water and then just shuts off and I don't think that the tub is turning in the wash cycle!!
Posted on Apr 21, 2010
In the back of your washer their should be a
diagnostic
manual behind the top cover. this manual will show you how to test the motor.
if the motor does not work. your motor control board is faulty. if you look closly at the board , you will see a burnt componet, that means you will need a upgraded board and unfortunely you will need in new motor to go with it.
it cost me around $230. has been working for 2 years with no other problems.
I found the parts on line. if you need help to find it , let me know, and when i get back home next week i will send it to you.
Good luck.
Posted on Aug 12, 2009
My nepton washer will not spin throught heavey loads but normal to medeum loads work fine
Posted on Apr 09, 2011
My NEC 892 has started banging when spinning noise. What could the problem be?
Normally just a badly loaded machine. Take all the clothes out and load them evenly around the drum for a top loader. For a front loader, take the clothes out and untangle them, lay them back in. Washing large single items like blankets or bedspreads are problematical at the best of times.
If it still persists, then my guess is that the shock absorbers or springs have broken or come adrift.
Nov 15, 2016 | Washing Machines
My front loader washer gets stuck on its last spin and wont drain properly. I am trying to wash a comforter and blanket. This is the 1st time its happened. Thank you
You may to mention the brand and model of machine. Mine is an Lg, I just shut off machine. Turn it back on and then press the no spin and start, this drains the washer. You may have too much clothes in the machine.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
Wfmc3200uc101 bosch washer doesnot spin out when a single sweater is in. the drum turns but not at full speed
i have the same problem, what i find helps put a bed sheet in with the sweater to even the load, ( I keep a sheet by the washer for this specifically) and take it off max. spin cycle for the small load (I know this sounds stupid) I have a bosch also and I have problems with small blankets too. This usually helps, but I found that if i do this under the 25 minute quick wash instead of the regular wash it doesn't spin out either, kind of stupid to run a machine with only one sweater for 58 minutes, I would never buy a front loader again, betty
Jan 21, 2011 | Bosch WFMC 3200 Front Load Washer
I just did a load of dog blankets, everything washed nicely, cleaned out the hair,put another load in of clothes, pushed the power button, heard a beep, pushed start and nothing happens.
Remove bottom panel.0da3616.jpg Get dog hair out of pump housing.a18b640.jpg
Tech sheet will be on that panel or behind that white box to the left.385ce31.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
Ariston front loading washing washing
Believe it or not.....its almost always the cloths ( heavy blankets) that one places inside.
TRY:: In the spin cycle if the load is unbalanced the TUB will rock and make that "loose drum out of alignment" noise. STOP the machine and open the door ( IF IT IS A TOP LOADER ) realign the cloths (heavy or more then one blanket) so that it is EVENLY spaced through out the tub.Start the machine again.If it does it again, stop the machine and REALIGN the cloths (blanket !!) again.
p.s. there is a simpler way of doing it but I don't want you to loose your hand in the process.
Aug 31, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Ripped door seal
It's usually not a good idea to wash single items in a front loader. This is because it can't properly balance the load. Either the item won't come out dry enough or if it does manage to spin the machine will shake violently until one of the shocks comes loose. When that happens the tub tilts down and to one side twisting the boot.
Jan 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
507 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
