Question about Lucent PARTNER18 Corded Phone
Adjusting the time on the phone
The phone has the incorrect time. How do I correct it?
FIRST GO IN SETTING THEN IN TME SETTING AND SET YOUR PROPER TIME INCLUDING "AM" AND"PM" .
Posted on Jun 29, 2009
In my nokia e63 it is saying that incorrect date and time but my date and time is correct
Confirm the month, date, year, & time is correct. If it still shows correct, try power cycling your phone and when it comes back online, confirm the error is gone and you still have the correct date & time.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Jul 31, 2016 | Nokia Cell Phones
Honda ctx200 fresh rebuild ran a couple times but started stalling backfiring when warmes up. took cover off found cam out by one tooth. adjusted and out together now it wont start at all. help please
Is it a dual cam engine? If so make sure can gear marks are aligned. Verify distributor is installed correctly set firing order is correct.only two things cause backfiring. Incorrect timing or incorrect plug wire position at distributor cap
Nov 19, 2014 | Cars & Trucks
Problem with sony cybershot camera showing incorrect date- how do i change the date?
If you know how much wrong the clock was set, ie.
The clock was 1999-01-01 14:37 but it should have been 2017-05-22 19:00, there are softwares that could correct this error for a directory of files.
just search for exif time offset correct software (exif is the files hidden information about the photo)
Nov 16, 2017 | Sony Computers & Internet
My son has a nokia 5025 that keeps changing time. Not sure how but the alarm has been going of at the set time , but the time has changed to an incorrect time somehow , not sure how he changes the time...
Please check if the "Auto Update time" feature is set to "ON" on your son's mobile. If it is set to ON, please try switching that option to OFF mode. I hope this will solve the issue. Also, please check if the time zone is correct.
Regards
Jun 07, 2011 | Cell Phones
How to adjust engine timing with new timing belt installed.
If you installed the timing belt correctly, you won't need to adjust the timing. If your timing is incorrect after doing the belt, you'll need to remove the belt again and install it with the cam and crank marks lined up properly.
May 30, 2011 | Geo Metro Cars & Trucks
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
He time on my motorola shows 16:10. How do I correct The Time please?
Most Motorola phones have a feature of "auto-adjustment" for correcting time. If this feature is enabled then your phone will not show the option to set the time manually. In order to correct the time manually you need to disable the "auto adjustment" feature. After disabling this manual adjustment settings will automatically come.
Hope this will help....cheers:)
Oct 01, 2010 | Motorola Cell Phones
Started feeding business card stock incorrectly - worked previously
You may need to have a technician adjust your copier or replace the rollers.
May 06, 2009 | Office Equipment & Supplies
Change clock display??
Press Feature.
Dial _9#.
Enter hour and minute via dialpad.
Press Recall to change AM/PM setting.
Press Hold to change to calendar setting.
OR Press Feature to exit this feature.
Press Recall to select day of week.
Dial # to move the cursor to day of month field.
Enter day of month via dialpad.
Press Recall to select month.
Dial # to move the cursor to year field.
Enter last two digits of year via dialpad.
Press Feature.
This must be done from a phone with attendant features set. Typically ports 1 and 2. More than likely x10, x100, x1000 or something like this.
Mar 12, 2008 | NEC Electra Elite 32D-1 Corded Phone
Lucent PARTNER18 Corded Phone Logo
93 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
