How to refill the 920 XL ink?
I am not sure where to punch or drill the hole to refill. Can anyone help me? Thank you.
Are you talking about the 920xl or some other cartridge , any more specific instructions i pealed the sticker back and there is one hole and a series of s's that looks like its where the body of the cartridge is put together. does this thing have a bladder or tank inside and how many ml's or cc's does it hold.
Posted on Jul 21, 2009
  • 258 Answers
All i do is put the hole in the top of the cylinder then refill the ink cylinder, but make sure you cover the hole with a sticker or something otherwise it will leak ink out of the bottom ok, it works
Posted on Jun 29, 2009
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
Tip
How to Refill the Epson R340's Ink Cartridge
<span>Instructional steps<br /></span> Things You'll Need: <ul> <li> <span>Syringes</span> </li> <li> <span>Refill ink</span> </li> <li> <span>1/16 inch thumb screw</span> </li> <li> <span>Paper towels</span> </li></ul> <ol> <li> Place the cartridge on a flat surface over some paper towels to soak up any spilled ink.<br /></li> <li>Drill a hole directly above the "H" in the word "Push" on the top label.<br /> </li> <li> Drill a hole above the the first hole so air can escape while you are filling the cartridge.<br /> </li> <li> Fill a syringe with the correct color and amount of refill ink. The black cartridge holds 25 ml of ink. Color cartridges hold 10 ml of ink.<br /> </li> <li> Insert the needle of the syringe into the first drilled hole. Slowly inject the ink into the cartridge.<br /> </li> <li> Replace the cartridge into the Epson R340. Allow it to rest for 24 hours so the ink can absorb into the sponge inside the cartridge.please rate this post by saying how helpful it is to you<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_7414161_refill-epson-r340_s-ink-cartridge.html#ixzz13r3MVnYc"><br /></a></span>
on Oct 30, 2010 | Office Equipment & Supplies
How to refill a canon lbp 2900 printer cartridge
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. 2
    Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. 3
    Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. 4
    Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. 5
    Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. 6
    Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Nov 10, 2010 | Canon LASER SHOT LBP-2900 Printer
I don't know how to refill
Hi Good day!!!
1. Spread newspaper or paper towels on a table to create a workspace protected from spills and accidental leaks. Set the cartridge on this workspace.
2. Remove the label on top of the cartridge. Use a razor to peel up one corner, if necessary, then peel back the rest.
3. Fill the syringe from your refill kit with between five to 10 milliliters of ink. Match the ink to the color listed on the cartridge.
4. Insert the syringe needle into one of the holes on top of the cartridge. If there are no holes in the cartridge, you must create one. Use a thumb drill (also included in your refill kit) to punch a small hole through the plastic.
5. Insert the needle into the cartridge. Inject the refill ink into the cartridge until it is full. Ink will bubble up around the hole when the cartridge is full. Fill the cartridge slowly to avoid mistakes and spills.
6. Place the cartridge back into the printer. Wait at least a few hours before printing. Some refill kits recommend waiting 24 hours before using the printer. Print a test page when the cartridge is ready.
Oct 26, 2010 | Computers & Internet
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
How i can refieling cartage
Its best that you go to web page of OASIS IMAGING, there are detailed instructions for Canon and HP remanufacturing.
But the most easyest way that you punch, or drill, or with soldering iron make an hole in crg, fill with toner and tape the hole.
But I recomend the Oasis whole procedure.
Jun 02, 2010 | Canon X25 Toner Cartridge for imageCLASS...
How do you refill a HP 920 ink cartridge
this will help you watch the video to refill HP 920 cartridge
1st
2nd
utube.png You-Tube video "kcFwQWCLiD8" placeholder
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 24, 2010 | Office Equipment & Supplies
How do i refill a canon printer cartridge
You need to put a strip of fexible eletrical tape over the large ink pad hole on the bottom front of the cartidge.
Drill a small hole at the top of the ink cartridge over the ink reservoir. (most refill kits come with a small bit to drill the hole). Fill the ink reservoir to 3/4. Put a piece of flexible electrical tape over the drilled hole to close the hole.
Voila! ... a refilled cartridge.
Most refill kits will have instructions.
Refilling can be messy so be careful and wear disposible latex gloves to avoid staining your hands. Also make sure you work over newpaper to catch any ink that you may drop.
Good luck.
I found that aftermarket cartridges are less than half the price of OEM cartridges and without the mess.
Aug 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Hp 920 xl ink cartridge filling instructions anyone have them
to refill 920:
1. If you have the plastic cap that covers the 9 mm. hole where you can see the sponge, then tape this cap to the cartidge with scotch tape. If not, use some duct/masking tape to cover the round hole.
2. Use the dry hypodermic needle to find the hole that will be found at the very center of the 920 label. With the needle, pierce the label.
3. Fill the hypodermic needle with 4 cc of ink.
4. Insert the needle 2-3 cm. into the hole made in step 2. Draw out 1 cc of air, then slowly force the 4 cc of ink into the sponge. Use toilet tissue to absorb any ink that might have escaped.
5. Let the catridge stand overnight (if possible) so as to allow the ink to evenly saturate the sponge. If not, insert it into your printer immediately.
Note: If you are going to refill catridges, be certain not to allow the sponge to dry completely. Thus, you might want to do step one immediately and to enclose it in a sealed sandwich bag upon removing an empty catridge from your printer even if you are not going to fill it immediately.
Jul 21, 2009 | HP Officejet 6500 Wireless All-in-One...
My printer won't print. I have ink in it but, it just won't print. I didconnected the plug in the back of the printer, and pluged it back in. But it won't print now. Can anyone help me? Thanks, keno
This printer will quit when you still have 1/5 of a cartridge and it makes you get a new cartridge--or get a Universal Ink Jet Refill package, drill a hole in the top, refill and tape over the hole (their instructions don't tell you how to do this cartridge, but its just as easy as any other)
view from top with hole drilled as the O:
_________________
! O !! !
!_______!!________!
May 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
1,016 people viewed this question
k24674
jasbo
jasbo
