Question about HP DeskJet 842c InkJet Printer
How to remove side covers to install new belts
    President:
  • 3,085 Answers
Release the tabs on the bottom of the machine. Not an eay job.
Posted on Jun 30, 2009
How to change image transfer belt unit on konika minolta bizhub c550
Transfer belts for the C550 series models are normally replaced by technicians. If you order the belt to install yourself, you turn off main power, open right side cover, locate guide plate under current belt, loosen thumb screw and remove plate, remove 2 screws securing the belt locks, remove front cable support on right side cover to lower cover, then pull belt out right side of machine. Install new belt in reverse order.
I would recommend a trained technician as the belts can become easily damaged.
Jul 18, 2017 | Konica Minolta bizhub Office Equipment &...
Tip
Tri Flex Deck Spring Bumper Kit Installation Instructions
Following are instructions on installing the tri flex deck spring bumper kit for the Quinton 3.0, Clubtrack, Clubtrack Plus, MedTrack CR60 and MedTrack SR60 treadmills.
  1. Set the treadmill to 5% grade and turn off the circuit breaker. Unplug the treadmill power cord from the outlet.
  2. Remove the front trim cover, hood, and both side rail covers.
  3. Relax the tension on the walking belt by removing the two screws in the rear end caps and the end caps.
  4. Remove the rear roller, then the front roller.
  5. Remove the walk belt and deck.
  6. Remove the compression mounts noting the position of the short and long mounts.
  7. Install the new compression mounts. DO NOT USE LOCTITE. Each side rail should have 5 long and 4 short compression mounts. The two rigid spacers will be installed in the rear holes.
  8. Install the slider bed (deck) and belt. Install the 12 6mm hex head screws using Loctite 242 on the threads. Torque to 30 inch-lbs.
  9. Replace the rollers, end caps, side rail covers, hood and front trim cover. Tension the walk belt and adjust belt tracking.
  10. Verify operation by operating the treadmill with a user at various speeds. Verify there are no unusual noises from the deck area .
http://www.sportsmith.net/page.aspx?did=01035F31-1611-489D-9B3F-E500A84EEC4F
on Mar 11, 2015 | Exercise & Fitness
Water pump 2000 3.0 liter dodge caravan
For The 3.0 Motor. (3.3 Way down the line.)
Drain cooling system.
Remove timing belt. Refer to Engine for procedure.
Remove water pump mounting bolts.
Separate pump from water inlet pipe and remove water pump.
Timing Belt Removal
Raise vehicle and remove accessory drive belt splash shield (Fig. 66).
Remove accessory drive belts.
Remove crankshaft pulley and damper (Fig. 68).
Support engine and remove right side engine mount.
Remove engine support bracket (Fig. 67).
Remove timing belt covers (Fig. 67).
Mark belt running direction for installation (Fig. 69).
Loosen timing belt tensioner bolt (Fig. 71) and remove timing belt.
Remove crankshaft sprocket flange shield (Fig. 68). CAMSHAFT SPROCKETS To remove camshaft sprockets
Hold camshaft sprocket with Spanner Tool MB-990775. Loosen and remove bolt and washer (Fig. 70).
Remove camshaft sprocket from camshaft. To install camshaft sprockets:
Place camshaft sprocket on camshaft.
Install bolt and washer to camshaft. Using Spanner Tool MB-990775, hold camshaft sprocket and torque bolt to 95 Nm (70 ft. lbs.) (Fig. 70). TIMING BELT TENSIONER
Install timing belt tensioner and tensioner spring.
Hook spring upper end to water pump pin and lower end to tensioner bracket with hook out (Fig. 71).
Turn timing belt tensioner counterclockwise full travel in adjustment slot and tighten bolt to temporarily hold this position (Fig. 72).
INSTALLATION
Install timing belt on crankshaft sprocket and keep belt tight on tension side (Fig. 69). Install belt on the front (radiator side) camshaft sprocket. Install belt on the water pump pulley, rear camshaft sprocket and finally on the timing belt tensioner.
Rotate the front camshaft sprocket in opposite direction to take up belt slack. Check that all timing marks are aligned (Fig. 69).
Install crankshaft sprocket flange (Fig. 68).
Loosen tensioner bolt and allow spring to tension timing belt.
Turn crankshaft two full turns in clockwise direction. Turn smoothly and in clockwise direction ONLY.
Align the timing marks on the sprockets and tighten the timing belt tensioner locking bolt to 28 Nm (250 in. lbs.) torque.
Install timing belt covers.
Install engine support bracket.
Install right side engine mount.
Install crankshaft damper and pulleys (Fig. 68). Tighten damper center bolt to 135 Nm (100 ft. lbs.) .
Install accessory drive belts.
Install accessory drive belt splash shield (Fig. 66).
Be sure to also replace all the cam and crank seals why you are there. Might as well put a belt on too.
FOR THE 3.3 OR 3.8 MOTORS.
Drain Cooling System.
Remove accessory drive belt.
Remove right front lower fender shield.
Remove water pump pulley bolts and remove pulley.
Remove water pump mounting screws. Remove water pump.
Remove and discard O-ring seal.
Clean O-ring groove and O-ring surfaces on pump and chain case cover. Take care not to scratch or gouge sealing surface
Installation
Install new O-ring into groove.
Install water pump to chain case cover. Tighten screws to 12 Nm (105 inch lbs.) .
Rotate pump by hand to check for freedom of movement.
Position pulley on pump. Install screws and tighten to 30 Nm (250 inch lbs.) .
Install accessory drive belt.
Install right front lower fender shield.
Refill Cooling System.
FOR THE 2.4 MOTOR
Disconnect negative cable from battery.
Raise vehicle on a hoist. Remove right inner splash shield.
Support engine from the bottom and remove right engine mount.
Remove right engine mount bracket.
Remove timing belt idler pulley.
Hold camshaft sprocket with Special tool C-4687 and adaptor C-4687-1 while removing bolt. Remove both cam sprockets.
Remove rear timing belt cover.
Install new O-ring gasket in water pump body O-ring groove. CAUTION: Make sure O-ring is properly seated in water pump groove before tightening screws. An improperly located O-ring may cause damage to the O-ring and cause a coolant leak.
Assemble pump body to block and tighten screws to 12 Nm (105 inch lbs.) . Pressurize cooling system to 15 psi with pressure tester and check water pump shaft seal and O-ring for leaks.
Install rear timing belt cover.
Install camshaft sprockets and torque bolts to 101 Nm (75 ft. lbs.) .
Install timing belt idler pulley and torque mounting bolt to 61 Nm (45 ft. lbs.) .
Install timing belt. Refer to Engine for procedure.
Install right engine mount bracket and engine mount. Refer to Engine for procedure.
Fill cooling system.
Lower vehicle and connect battery cable.
Mar 29, 2012 | Cars & Trucks
How i do the timing on my 87 subaru gl awd
It's a bit of a pain but here is what you set it to:
Aligning the marks on the flywheel with the marks on the flywheel cover
Driver side timing belt (No. 2) and No. 2 tensioner-1.8L engine
Passenger side timing belt (No. 1) and No. 1 tensioner
  1. Disconnect the negative battery cable.
  2. Loosen the water pump pulley mounting bolts.
  3. Loosen the alternator mounting bolts and remove the alternator belt.
  4. Remove the water pump pulley bolts and remove the water pump pulley.
  5. Disconnect the electrical harness from the oil pressure switch.
  6. Remove the dipstick tube.
  7. Remove the crankshaft pulley.
  8. Remove the timing belt cover plate, if equipped.
  9. Remove the timing belt cover bolts on the left, right, and center covers.
  10. Remove the timing belt covers.
  11. Remove the rubber cover seal. Clean all mating surfaces.
To install:
  1. Install a new timing belt cover seal.
  2. Install the timing belt covers on the engine using the mounting bolts. Tighten the bolts to 48 inch lbs. (5 Nm).
  3. Install the timing belt cover plate, if removed.
  4. Install the crankshaft pulley, and tighten the bolt to 69-76 ft. lbs. (93-103 Nm)
  5. Install the dipstick tube.
  6. Connect the electrical harness to the oil pressure switch.
  7. Install the water pump pulley and loosely install the mounting bolts.
  8. Install the drive belt and adjust the tension as necessary. Tighten the alternator mounting bolts.
  9. Tighten the water pump pulley mounting bolts.
  10. Connect the negative battery cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 77; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]>
Jun 20, 2011 | 1987 Subaru Gl 4WD
Ifailed to get on tdc before removing old timing belt how do I get back in time so Icanreplacebelt.
This is the complete procedure from the service manual on how to replace the timing belt start to finish, start over to assure u get it right, if u mess up the engine will be damaged
Removal for 1.6L engines : ONLY 2006 to 2009 CARS
Engine removal is not required for this procedure.
1.Remove the engine cover.
2.Remove the RH front wheel.
3.Remove the 2 bolts and RH side cover.
4.Temporarily loosen the water pump pulley bolts.
5.Remove the alternator drive belt
6.Remove the air conditioner compressor drive belt
7.Remove the power steering pump drive belt
8.Remove the 4 bolts and water pump pulley.
9.Remove the 4 bolts and
timing belt2_bing.gif upper cover
10.Turn the crankshaft pulley, and align its groove with timing mark "T" of the timing belt cover. Check that the timing mark of camshaft sprocket is aligned with the timing mark of cylinder head cover. (No.1 cylinder compression TDC position)
11.Remove the crankshaft pulley bolt and crankshaft pulley
12.Remove the crankshaft flange
13.Remove the 4 bolts and timing belt lower cover
14.Remove the timing belt tensioner and timing belt.
15.Remove the bolt and timing belt idler
16.Remove the crankshaft sprocket
17.Remove the cylinder head cover.
(1)Remove the wire harness bracket
(2)Remove the ignition coil.
(3)Remove the PCV (Positive Crankcase Ventilation) hose and the breather hose from the cylinder head cover
(4)Remove the engine cover bracket
(5)Loosen the cylinder head cover bolts and then remove the cover and gasket.
18.Remove the camshaft sprocket.
Hold the portion of the camshaft with a hexagonal wrench, and remove the bolt with a wrench and remove the camshaft sprocket.
INSTALLATION:
1.Install the camshaft sprocket and tighten the bolt to the specified torque.
(1)Temporarily install the camshaft sprocket bolt
(2)Hold the portion of the camshaft with a hexagonal wrench, and tighten the bolt with a wrench
Tightening torque :78.5 ~ 98.1N.m (8.0 ~ 10.0kgf.m, 57.9 ~ 72.3lb-ft)
2.Install the cylinder head cover.
(1)Install the cylinder head cover and bolts
Tightening torque :7.8 ~ 9.8N.m (0.8 ~ 1.0kgf.m, 5.8 ~ 7.2lb-ft)
(2)Install the engine cover bracket
(3)Install the PCV(Positive Crankcase Ventilation) hose and breather hose to the cylinder head cover.
(4)Install the ignition coil.
3.Install the crankshaft sprocket
4.Align the timing marks of the camshaft sprocket and crankshaft sprocket with the No.1 piston placed at top dead center and its compression stroke.
5.Install the idler pulley and tighten the bolt to the specified torque.
Tightening torque :42.2 ~ 53.9N.m (4.3 ~ 5.5kgf.m, 31.1 ~ 39.8lb-ft)
6.Temporarily install the timing belt tensioner
7.Install the belt so as not give slack at each center of shaft. Use the following order when installing timing belt.
Crankshaft sprocket →idler pulley →camshaft sprocket →timing belt tensioner
8.Adjust the timing belt tension.
(1)Loosen the tensioner pulley mounting bolt and apply tension to the timing belt.
(2)After checking the alignment between each sprocket and each timing belt tooth, tighten the mounting bolt and one by one.
Tightening torque :19.6 ~ 26.5N.m (2.0 ~ 2.7kgf.m, 14.5 ~ 19.5lb-ft)
(3)Then recheck the belt tension.
Verify that when the tensioner and the tension side of the timing belt are pushed in horizontally with a moderate force [approx. 49N (11lb)], the timing belt cog end is aprox. 1/2 of the tensioner mounting bolt head radius (across flats) away from the bolt head center.
4)Timing belt tension measuring procedure
(by a sonic tension guage)
Rotate crankshaft in clockwise direction to set 1st piston on top dead center (TDC) and rotate crankshaft in counterclockwise to 90° then measure the belt tension in the middle of tension side span (in arrow direction of above illustration) by free vibration method.
9.Turn the crankshaft two turns in the operating direction (clockwise) and realign crankshaft sprocket and camshaft sprocket timing mark.
10.Install the timing belt lower cover with 5bolts
11.Install the flange and crankshaft pulley, and then tighten crankshaft pulley bolt. Make sure that crankshaft sprocket pin fits the small hole in the pulley.
Tightening torque :137.3 ~ 147.1N.m (14.0 ~ 15.0kgf.m, 101.3 ~ 108.5lb-ft)
12.Install the timing belt upper cover with 4 bolts.
13.Install the water pump pulley and 4 bolts.
14.Install the power steering pump drive belt
15.Install the air conditioner compressor drive belt
16.Install the alternator drive belt
17.Install the RH side cover with 2 bolts
18.Install the RH front wheel.
Tightening torque :88.3 ~ 98.1N.m (9.0 ~ 10.0kgf.m, 65.1 ~ 72.3lb-ft)
19.Install the engine cover with bolts.
Tightening torque :3.9 ~ 5.9N.m (0.4 ~ 0.6kgf.m, 2.9 ~ 4.3lb-ft)
May 20, 2010 | 2006 Kia Sorento
I need to know how i can get to my water pump and what all i need excatly to fix it
  2. Drain the coolant into a suitable container.
  3. Disconnect the radiator outlet hose.
  4. Remove the radiator fan motor assembly.
  5. Remove the accessory drive belts.
  6. Remove the timing belt, tensioner and camshaft angle sensor. Refer to the procedure in this section for removal and installation steps.
  7. Remove the left side camshaft pulley(s) and left side rear timing belt cover. Remove the tensioner bracket.
  8. Disconnect the radiator hose and heater hose from the water pump.
  9. Remove the water pump retainer bolts.
  10. Remove the water pump.
To install:
  1. Clean the gasket mating surfaces thoroughly. Always use new gaskets during installation.
  2. Install the water pump and tighten the bolts, in sequence, to 7-10 ft. lbs. (10-14 Nm). After tightening the bolts once, retighten to the same specification again.
  3. Inspect the radiator hoses for deterioration and replace as necessary. Connect the radiator hose and heater hose to the water pump.
  4. Install the left side rear timing belt cover, left side camshaft pulley(s) and tensioner bracket.
  5. Install the camshaft angle sensor, tensioner and timing belt.
  6. Install the accessory drive belts.
  7. Install the radiator ran motor assembly.
  8. Install the radiator outlet hose.
  9. Fill the system with coolant.
  11. Start the engine and allow it to reach operating temperature.
  12. Check for leaks.
Jan 20, 2010 | 1992 Subaru Legacy
How to change head gasket?on gas v6. ISUZU RODEO Vin #452CG58V554341786
This is the same for many years. I will send this in 2 post it is to long. Hope this helps you. From the '00 Rodeo workshop manual:
Cylinder Head Assembly
Removal
1. Disconnect battery ground cable.
2. Disconnect connector of intake air temperature
sensor from intake air duct.
3. Remove PCV hose from air intake duct.
4. Remove nut from air intake duct bracket and loosen
hose clamp on throttle body. Remove air intake duct
assembly with air cleaner cover.
5. Remove intake air duct bracket from cylinder head.
6. Drain engine coolant.
7. Move drive belt tensioner to loose side using wrench
then remove drive belt.
033RW001
8. Remove radiator upper hose from engine side.
9. Remove four nuts of exhaust front pipe.
10. Remove three bolts from generator bracket then
remove the generator with brackets.
065RW025
11. Disconnect crankshaft angle sensor connector.
12. Disconnect knock sensor connector.
13. Remove heater hose from adapter side.
14. Remove heater hose from water pipe side.
15. Remove water hose between water pipe and throttle
body.
16. Remove fuel pipe joint eye bolts from fuel rail
assembly and remove fuel pipe bracket with electric
ground cable.
042RW001
17. Disconnect connector for evaporation valve.
18. Remove canister hose.
19. Remove fixing nut of intake manifold stay from
cylinder block side.
025RW002
20. Remove two bolts from intake manifold for water pipe
support and remove cylinder head assembly.
21. Remove engine harness cover and disconnect three
connectors from chassis harness on left rear side
engine compartment.
22. Disconnect connector for power steering pump
pressure switch.
23. Remove four bolts and remove crankshaft pulley.
ENGINE MECHANICAL (X22SE 2.2L) 6A–23
020RW014
24. Remove two bolts and nut then remove timing belt
front cover.
25. Remove ventilation hose from cylinder block side and
from cylinder head side.
26. Remove two bolts, ignition cable cover and remove
ignition cables from spark plug.
27. Disconnect camshaft angle sensor connector.
28. Remove ten bolts and remove cylinder head cover.
29. Remove fixing bolt of timing belt tensioner then
remove timing belt tensioner.
020RW010
30. Remove timing belt.
CAUTION:
 Do not bend or twist belt, otherwise its core could
be damaged. The belt should not be bent at a
radius less than 30 mm.
 Timing belt drive gear counterhold with J–42620.
 Do not allow oil or other chemical substances to
come in contact with the belt. They will shorten
the life.
 Do not attempt to pry or stretch the belt with a
screw driver or any other tool during installation.
 Store timing belt in cool and dark place. Never
expose the belt direct sunlight or heat.
31. Remove two idle pulleys, the left side with idle pulley
bracket.
32. Remove two bolts and stud bolt and remove timing
belt rear cover.
33. Remove camshaft angle sensor
34. Disconnect engine oil pressure switch connector.
050RW005
35. Remove camshaft assembly exhaust side.
36. Use J–42623 to remove ten cylinder head fixing bolts
012RW007
6A–24 ENGINE MECHANICAL (X22SE 2.2L)
Installation
1. Put cylinder head gasket on the cylinder block.
012RW011
2. Install the cylinder head assembly, tighten cylinder
head bolts by four steps tightening method in the
following sequence to the specified torque.(use
J–42623)
Torque: 25 N·m (18 lb ft) + 90 + 90 + 90
012RW006
3. Install camshaft assembly exhaust side and tighten
camshaft bracket bolts in the sequence to the
specified torque.
Torque: 8 N·m (5.9 lb ft)
015RW014
4. Connect engine oil pressure switch connector.
5. Install camshaft angle sensor.
6. Install the timing belt rear cover and tighten three
bolts to the specified torque.
Torque
M6 bolt: 6 N·m (4.4 lb ft)
M8 bolt: 8 N·m (5.8 lb ft)
020RW012
7. Install left side idle pulley with idle pulley bracket,
tighten to the specified torque and install right side
idle pulley and tighten to the specified torque.
ENGINE MECHANICAL (X22SE 2.2L) 6A–25
020RW016
Oct 09, 2009 | Isuzu Rodeo Cars & Trucks
Need the belt diagram for the water pump belt for a 95 Auroa
42161874BELT, REPLACE
  1. Release belt tension and remove belt from power steering and alternator pulleys. Twist belt to get between tensioner and front cover and between power steering pulley and engine mount bracket.
  2. Raise and support vehicle.
  3. Turn wheel to the extreme right and remove right side splash shield.
  4. Remove belt from crankshaft and A/C compressor pulleys. Twist belt to get between idler pulley and engine mount bracket.
  5. Lower vehicle.
  6. Twisting new belt to get past the front cover, install belt around power steering pump pulley, Fig. 15. Allow belt to hang free.
  7. Twist belt to get between tensioner and front cover, wrap belt around alternator.
  8. Remove belt from power steering pulley and set aside.
  9. Raise and support vehicle, then twist belt to get between tensioner and front cover, wrap belt around crankshaft and A/C compressor pulleys.
  10. Install right side splash shield and lower vehicle.
  11. Position belt around power steering pulley and release tensioner.
Nov 23, 2008 | 1995 Oldsmobile Aurora
Replacing water pump on a dogge Caravan 1996
Alright, here's a pic of the mechanicals:
The bad news is on your vechile you have to remove the timing belt, but here's a step by step.
  2. Remove the drive belts.
  3. Drain the cooling system.
CAUTION When draining coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Remove the timing case cover and timing belt. Refer to Timing Belt Covers and Timing Belt Removal procedures.
  2. Remove the pump assembly mounting bolts.
  3. Separate the pump assembly from water pipe and remove.
  4. Clean gasket and O-ring mounting surfaces.
  5. Install a new O-ring on water pipe and lubricate with water.
  6. Install a new gasket on pump body.
  7. Press the water pump assembly into water pipe.
  8. Install pump mounting bolts and tighten to 27 Nm (20 ft. lbs.).
  9. Install timing belt and cover. Refer to Timing Belt procedures.
  10. Install drive belts.
  11. Fill the cooling system
To remove timing:
The timing belt can be inspected by removing the upper (front outer) timing cover.
  2. Remove the accessory drive belts.
  3. Remove the timing belt covers.
  4. Identify the timing belt running direction to avoid reversal during installation.
  5. Loosen timing belt tensioner bolt and remove timing belt.
  6. Remove the crankshaft sprocket flange.
To install:
  1. Rotate the crankshaft sprocket until timing mark on crankshaft sprocket is lined up with the oil pump timing mark at 1 o'clock position.
  2. Rotate the (inner) camshaft sprocket until mark on (inner) camshaft sprocket is lined up with the timing mark on alternator bracket.
  3. Rotate the (outer) camshaft sprocket (radiator side) until mark on the sprocket is lined up with the timing mark on the timing belt inner cover. Refer to timing belt illustration.
  4. Install the timing belt on the crankshaft sprocket while maintaining pressure on the tensioner side.
  5. Position the timing belt over the camshaft sprocket (radiator side). Next, position the belt under the water pump pulley, then over the (inner) sprocket and finally over the tensioner.
  6. Apply rotating force in the opposite direction to the camshaft sprocket (radiator side) to create tension on the timing belt tension side.
  7. Rotate the crankshaft in a clockwise direction and recheck engine timing marks.
  8. Install the crankshaft sprocket flange.
  9. Loosen the tensioner bolt and allow tensioner spring to tension the belt.
  10. Again rotate the crankshaft in a clockwise direction (2) full turns. Recheck the engine timing. Tighten the tensioner bolt to 23 ft. lbs. (31 Nm).
  11. Install the timing covers.
  12. Install the accessory drive belts.
  13. Connect battery negative cable.
Hope this helps.
Jun 27, 2008 | 1996 Dodge Caravan
Install a new 4476 belt
What kind of vacuum is it you have?
Nov 30, 2007 | Vacuums
HP DeskJet 842c InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
