Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Date stamp will not show on my camera
I try to highlight the date stamp option in the startup menu of my SD 630 but it skips right over the option. How do I get the date stamp to function
I found the solution o-line. All I had to do was switch the camera to the 'postcard' mode and instant presto, I was able to access the date stamp mode. I want to express my thanks to the (I don't remember who) person who posted the solution.
Posted on Jul 01, 2009
I would like to turn the date stamp off... I do not like it in the pictures
Using the Capture Menu
The Capture Menu allows you to adjust camera settings that affect the characteristics
of the images and video clips you capture.
1. While in Live View or Playback, press , then use to highlight .
2. Use to highlight a menu option, then press to display the menu option's
sub-menu.
3. Use to highlight a setting, then press .
4. Press to exit the Capture Menu.
For on-camera information about an option, use to highlight Help... in the option's
sub-menu, then press .
In the capture menu goto
Date & Time Imprint Imprints date in lower left corner of image.
Off Default No date or time imprinted on the image. (this setting)
Date Only Date permanently imprinted.
Date & Time Date and time permanently imprinted.
this should fix your problem
Mar 18, 2014 | HP Photosmart M525 Digital Camera
How do you stamp date photos on the M580 easyshare camera
1. Press the Menu button.
2. If your camera displays a menu with tabs at the top:
a) Press the Right/Left buttons to highlight the Setup tab.
b) Press the Down button to highlight Date Stamp.
c) Press the OK button to add the date stamp to new pictures.
3. If your camera does not display a tabbed menu:
a) Press the Down button to highlight Date Stamp. NOTE: Depending on your model, Date Stamp might be within the Setup choice.
b) Press the OK button to add the Date Stamp to new pictures.
Apr 11, 2011 | Kodak EasyShare M530 Digital Camera
How do you date stamp pictures
Apr 11, 2011 | Kodak Easyshare M580 Digital Camera
How can I set up the camera to put a date stamp on each photo when it is taken?
Press the Menu button. Use cursor-up/down to highlight Setup and press OK. Use cursor-up/down to highlight "Date Stamp" and press OK. Choose an option and press OK. Press Menu to exit.
Mar 11, 2011 | Kodak Easyshare C813 Digital Camera
How to remove date stamp from screen?
In the lower left corner of the back of the camera just to the right of the LCD screen is a button marked "disp" by pressing the button it will change the different screen modes on should show only the picture without the numbers or writing on it.
Dec 26, 2010 | Canon PowerShot SX20 IS Digital Camera
When I print photos, it doesn't show the date on the photo. Also , when I scroll down to Date/Stamp on the menu, it is always "off". And I can't change the setting. Help
You haven't said what make/model your camera is, so it is hard to advise.
Without knowing the camera, I am guessing that you may be in the wrong mode when trying to change this setting. You won't be able to change it while reviewing pictures already taken. You can only change it for pictures to be taken subsequently. Once pictures are taken, you won't be able to add the date stamp, nor remove it if it has been stamped.
It may be that it won't allow you to set this if you haven't already set the date and time in your camera. I can't see why this setting would be shown at all if it was not possible to turn it on (i.e. if your camera did not have this feature).
Nov 03, 2010 | Cameras
How do you remove the date from the picture, but still have the camera associate the date in your computer? When I set the date, it started showing up on all my pictures and I do not want it there.
Press the Menu button. Press cursor-up/down to select "Date Stamp" (rubber stamp icon) and press OK. Use cursor-up/down to highlight an option and press OK. Press Menu to exit the menu.
Oct 13, 2010 | Kodak EasyShare DX4530 Digital Camera
Purchased a Kodak easyshare M320 can not figure out how to set
You have two options for getting the date printed on your pictures. One is to set the appropriate option in whatever software you're using to print. The other is to have the camera put it there in the image itself. This means that if the date happens to cover something important, you won't be able to get it back.
To set the camera to put the date stamp on every picture, press Menu, use left/right to highlight Setup, then use up/down to access "Date Stamp".
May 20, 2010 | Kodak EASYSHARE M340 Digital Camera
Date stamp option in menu will not highlight to change it just skips past it change daye and time
For some cameras this option only works when the camera is set to a specific resolution. Some calle this resolution "Postcard" resolution, and is usually 1200 pixels width. Try setting your camera to its other resolutions to see if this ocrrects the problem. Suggest that you start with 1200 x 900 resolution. Keep in mind that this 1200 x 900 gives only 1 megapixel resolution. Most newer cameras are capable of taking much higher resolution pictures, so this may be a trade-off if you want to use the date stamp option.
May 10, 2009 | Cameras
Date stamp
In order to use the date stamp option, the image size (L, M1, M2, M3, S, Postcard) has to be set to Postcard. Press the Func/Set button, scroll down to the image size icon (lower left corner), then scroll over to Postcard, and press the Func/Set button again.
Jun 10, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
529 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
