Question about Polaris 380: Polaris Booster Pump
Removing impeller from polaris 380 pump
How do you remove impeller from pump without acess ports?
    Top Expert:
  • Polaris Master
  • 8,686 Answers
Remove all screws from around pump
Posted on May 22, 2016
Piaa
  • 8 Answers
SOURCE: I am wondering in what position should the reverse
You will have some serious problems if you don't put the reverse thruster in the correct position. Be sure to read the instructions carefully. Look at the pictures closely if there are any. Get a magnifying glass to see the detail and position of the part. If not call the toll free number of the manufacturer and ask them exactly what you need to know.
Posted on Jun 10, 2009
john224
  • 1378 Answers
SOURCE: I have a Polaris PB4-60
You need to lock the other end of the motor shaft and then spin off the impeller. If you would like a quote on the replacement seal, contact us at www.arrowpools.net
Posted on Jul 12, 2009
  • 990 Answers
SOURCE: My polaris 380 wheels won't turn. the belt is
If the wheels don't turn there may be sand in the notches on the wheels, the notches may be worn off, if their is sand or dirt in the paddel wheel jet that will keep the unit from turning and again no wheel movement. All of these problems they can check in your local pool store. Stores will generely check your unit out and fix what is needed for just the price of parts to fix it when you bring it into the store.
If you have no water flow to the unit this will also stop things from working so be sure to check your finger screen before you do anything.
Posted on Aug 25, 2009
  • 990 Answers
SOURCE: polaris pump not moving my polaris impeller in
Did you ck your finger screen? ether in the wall or in the hose.
Posted on Oct 04, 2009
  • 10 Answers
SOURCE: My 4-year old polaris 380 frequently blows
Once you fix the immediate problem with zip ties, check the wheel RPM. It should be between the range of 28 to 32.To check the RPM Hold the cleaner completely under the water and count the wheel revolutions for one minute. If your RPM is to high, you can adjust it at the wall with pressure relief valve by unscrwing it. Im willing to bet your pressure is excessive. This page should also help: Polaris Troubleshooting Page
Posted on Nov 03, 2009
My Polaris 380 disconnects from quick disconnect. seems like a lot of pressure behind it.??
Take out the wall fitting of each of the two locking taps are probably gone there are restricted behind the wall fitting blue or red either remove or I stall
Aug 31, 2016 | Polaris 380 Pool Cleaner - Pressure
Change belts on polaris 380
open case then remove vertical tube then then remove paddle wheel assy then you have to remove wheel screws to change belts take pictures as you take it apart
Jul 29, 2012 | Polaris 380 In Ground Pool Cleaner
I am having difficulty removing the impeller on my BaquaPure 2.0 Horse Power pool pump
reverse screw and regular thread on impeller hold back of motor with 9/16 wrench
Jul 06, 2012 | Polaris Pb460 Polaris Booster Pump...
My brand new Polaris 380 booster pump is noisy. What do I do?
Thank you for posting your question here on Fixya.com.
It is likely due to cavitation in the booster pump impeller. The easiest way to correct the issue is to slowly close a throttling valve on the booster discharge. If there is not one present install a ball or gate valve near the pump discharge line and slowly close it with everything running until the noise stops. Generally speaking closing the valve about a quarter of the way seems to be when most pumps run quietly but the setting is unique to each installation.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
May 14, 2011 | Polaris 380: Polaris Booster Pump
I am having difficulty removing the impeller on my Polaris PB4 Booster pump. I removed the seal plate and held the motor and attempted to turn the impeller counterclockwise. Can't get the impeller to...
For an impeller really stuck on the motor shaft you need to pull the motor thru-bolts and remove the rotor with the pump still attached from the stator. Lock the rotor in a vice and turn the impeller off with a large set of channel locks or a large strap wrench.
John
Nov 07, 2010 | Polaris Pb460 Polaris Booster Pump...
My no flow light is on and the polaris won't move
Not too much to go on but i'll give it a shot. Polaris won't move cause there is no or little water pressure. A number of things can cause this, and i'll give you the most common. Dirty or clogged filter. If it's a cartridge type, remove cartridge and try running without it. Clogged output of pump. No input to pump. Make sure pump is primed.
Mar 22, 2010 | Polaris 380 In Ground Pool Cleaner
I have a Polaris PB4-60 Booster Pump with a leaking seal. I have removed the Volute and removed the 4 bolts that hold the bracket to the motor. How do I remove the impeller? At the store they told me it...
Jul 11, 2009 | Polaris Pb460 Polaris Booster Pump...
There is a noise (hum) when the spin is set. No spin.
probably pump plugged if that is a front load remove bottom panel pump has a clean out port clean thoroughly and retry is still only hum pump impeller may be jammed or damaged ..removing pump will allow better acess to impeller area
Aug 22, 2008 | Whirlpool Washing Machines
Polaris 380: Polaris Booster Pump Logo
60 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
