Question about Microsoft Xbox 360 Console
From my xbox 360 i hooked the red white and yellow cables into video 1 and the blue red and green cables into component 2 then switched the cable from my xbox to hdtv but now i have sound on video1 but no picture and picture but no sound on component 2. how do i get both?
    Problem Solver:
  • 5 Answers
All together is for hd gaming take out red,blue,green see if that helps
Posted on Jun 29, 2009
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
How do i connect xbox to akura apl3268fd4 tv so its in hd
There are two ways to connect it.
1. The cable that came with your xbox should have two sets of plugs on it. One being the red, white, yellow and the other red, green, blue. You need to plug the red, green, and blue plugs into the tv with the same color plugs. You will also have to plug in the red and white for sound. The yellow plug is not needed. There will also be a switch at the base of the cable near the xbox. That needs to be set to HDTV. If your cable does not have the red, green, blue you will need to buy a cable that does have them.
2. You can use an HDMI cable. With that all you need to do is plug one end of the HDMI cable into the xbox and the other into the tv. Not all xbox's have the HDMI output though. If its new i should have it on the back of the xbox near the normal tv output slot.
If you use the red, green, blue you will have to set your tv on the component channel. If you use HDMI the tv will have to be on the HDMI channel
This will give you a more thorough explanation. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/audio-video.aspx
If you found this helpful please give me a good rating. Thanks hope this helps
Nov 21, 2010 | Video Game Consoles & Games
How to hook up ur xbox 360 to ur tv to play ur xbox 360
if your using the hdmi cables you have to plug in the green, blue and red cables into the corresponding sockets on the tv, the plug the red and white ones into sockets which are not in the same area as the normal red white and yellow cables, there should be a row of sockets at the bak of your tv:
Green
Blue
Red
White
Red
Dec 22, 2009 | Microsoft Xbox 360 Console
Trouble with 360 and hdtv
The cable your refering too are called Component leads.
The red and white are for your audio and the remainder are the video. All you need to do is connect the component leads matching up all the colour in the correct ports then using your av/source button change the tv to component
You will still have to connect the red and white audio cable to the tv as well.
that should sort your xbox out.
cheers
Little Dish Fitter
Sep 18, 2009 | Proscan PS36700 36" TV
Xbox 360 hookup problem
Check the video cable coming out of the xbox, depending on which model xbox it is (arcade, pro, elite etc.) it will most likely have both component cables - green, blue and red or RCA cables - Yellow, red and white. It sounds as if your JVC would only be able to run RCA cables (due to its age) so use the yellow cable for video and white and red (or just white if you only have a yellow and white input) and then make sure the switch located on the cable is switched to "standard" and not "hi definition" hope it helps. aus_joel@hotmail.com -if you have any further problems
Jul 06, 2009 | JVC LT-47X788 47 in. LCD HDTV
I get sound but no picture on my xbox 360
Wiggle the end of the cord a little bit. same thing happened to me
Jun 27, 2009 | Microsoft Xbox 360 Console
XBOX not connecting to LG flatscreen -no visuals only sound
There is a switch on the cable where it plugs into the XBOX that says HDTV/TV please make sure that it is set to HDTV when using component connectors.
May 13, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
When connecting XBOX live to LG flatscreen there is no video only
There should be a switch on the cable that says HDTV/TV if you are using component connections, make sure that the switch is set to HDTV.
May 12, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
Xbox 360
What cables are you using to connect to tv?
There's
1) Yellow and Red+White
2) Red+Blue+Green and Red+White
3) HDMI and Red+White
Cable Couplers
1) 3002 and two 685 rca rgb coupler f/f + rca coupler f/f
2) 3002 and two 685 rca rgb coupler f/f + rca coupler f/f
3)3663 15feet hdmi cable
above numbers can be searched at monoprice.com
Jan 24, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
114 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
