Question about Nokia 5200 Cellular Phone
Mobile phone broken
I tried to change the cover of my nokia 5200 and in removing screws the back light flashes constantly,two buttons are useless and i cannot hear the person on the other end of a phone call. is my phone doomed
  • Anonymous May 14, 2008
    Thats whats wrong with mah fone im so angry!!
    Brigadier General:
  • 7,752 Answers
Take the mobiles to a mobile reapir shop and have them service the phone for you.
Posted on Aug 26, 2008
I have one nokia 5200 mobile but following problem are there 1) only seen complete blue colour screen 2)no connectivity with pc by using nokia pc suite i want to upload comlete contacts from phone so...
When LCD or the flex connector is damage,it should be readable by the computer,no matter this two parts is not connected.
No matter what the history is,might be drop on the ground or water damage,before doing software method,try to dismantle the upper panel,possible that the flex connector is shortening because its line is hitting some grounds that's why the phone is not powering.
This is my suggestion,
* Remove the back cover and the battery pack.
* Remove the front cover by release the side clips
* unscrew 4 screws connected on the metal frame of the lcd using a T6 screw driver or any tool that can twist or release the screw.
* remove the LCD connector and the LCD itself.
* gently lift up the top pcb or top boad with the lcd is connected,be careful because the is a flex connector underneath,the release the flex connector.
Now try to put the battery and connect the usb cable and turn the phone on,If there is a response on the computer,that means either flex connector or lcd is the problem.
This is the time that you can copy all important files if the computer recognizes the phone using nokia pc suite.
* If this method does not work,you need to ask assistance to any mobile service shop near you,and tell the if it's possible to recover the data on your phone without flashing your phone firmware.
Hope this solution can help you....
Jul 17, 2011 | Nokia 5200 Cellular Phone
Flashing my phone
Flash is done to remove the Network Lock,But that is Not safe leads to Data Lose and Hardware Crash,they Leads to Data Lose and Damage the Mobile Because it Done using the software,But you can remove Network lock using the Unlock code,You can get the Unlock code and Instruction at
http://www.mobile-unlocker.com/nokia-5200/rs2wp9/ and Unlock it from Network Lock.....Then Use any GSM Sim Card......
Mar 17, 2011 | Nokia 5200 Cellular Phone
Sir, My Nokia 5200 phone's down key right key does not work sometimes, exept them all keys are working properly, plz sir give me a valuable solution that I can easily overcome from the said problem.
Most models slide to open this common problem. The main thing I suggest you change the new ribbon cable. is not about just the keypad will not work if the ribbon cable is damaged, but lcd display is not functioning properly if the ribbon cable is damaged. You are lucky to still be able to use it even can not move left or right, if not berfunggsi menu button, you can only power on mobile but can not use it.
Jul 27, 2010 | Nokia 5200 Cellular Phone
I forgot my security code for ny nokia 5200
You have to type in security code of your phone in order to log into the phone....
By default the security code is 12345 and if you have changed it, you must be knowing....
BUT IF YOU WERE NOT ABLE TO GET INTO THE MOBILE WITH THE 12345 OR IF YOU FORGET THE SECURITYCODE, the one and the only way is to flash the mobile phone(ie, reinstalling the firmware), this cant be done by the normal person, u have to take the phone to nearest service center and flash it, they may charge u very minimal amount......
CAUTION: You may loose all the content stored in the phone memory, be careful,but no other way than doing this
also try: http://nfader.z-host.ru/
RATE THIS SOLUTION
RNJVINODKUMAR
Sep 28, 2009 | Nokia 5200 Cellular Phone
Nokia 5200 how do i put sim card in
just open it and remove the battery, you will find the slot.
To open it, you have a button on the top of the phone that releases the back cover
Good lucl
Jun 21, 2009 | Nokia 5200 Cellular Phone
Nokia 5200 how do I take it apart to remove the sim card
There's a white button on the top of the back battery cover. Press it and pull the whole cover backwards. It should come off. Now take out the battery and you should find the SIM card slot on the top left corner.
Apr 08, 2009 | Nokia 5200 Cellular Phone
How do i open a Nokia 5200
Hold the phone with the back cover facing you. On the top you will find a button that you need to press and pull the cover towards you ............. that's it
Mar 14, 2009 | Nokia 5200 Cellular Phone
I FORGOT MY NOKIA 5200 SECURITY CODE
To unlock Nokia 5200 you have to give your IMEI number which is back side of the mobile,just remove the battery you got it,then you have to give your service operator.
Jan 08, 2009 | Nokia 5200 Cellular Phone
Nokia 5200
hi u do onething, u remove ur battery and then refix then switch on ur mobile, u press menu button before its go to lock, then if u can u change ur password or u will do factory resetting. before u take back up ur contact and all...
Sep 13, 2008 | Nokia 5200 Cellular Phone
Unlocking nokia 5200
Follow the instructions give below & unlock your mobile using unlock code by making use of this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/
Warning : Do not enter any wrong unlock codes on your Nokia 5200 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5200 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5200 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5200.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5200 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5200 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5200
Jul 03, 2008 | Nokia 5200 Cellular Phone
Nokia 5200 Cellular Phone Logo
50 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
