Tomtom Via 1535tm GPS Receiver Logo
A
Anonymous Posted on Jul 18, 2014
Just got new via1535tm need operators manual. How to set blue tooth for phone and all basic operation from how to turn off and on
compusat
Level 2:
Sergeant:
Champion:
  • Tomtom Expert 373 Answers
  • Posted on Jul 19, 2014
compusat
Tomtom Expert
Level 2:
Sergeant:
Champion:
Answers
373
Questions
0
Helped
44891
Points
507
1 Related Answer
Anonymous
  • 515 Answers
  • Posted on Oct 10, 2008
SOURCE: have a tomtom one and
Always let TT device find your phone, never the other way around....
TT will tell you to type 0000 as password on phone when needed.
4helpful
Need operating instructions for Jabra BT 2080 headset
ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
1helpful
My nokia n70 bluetooth is telling me unable to perfome bluetooth operation what is solution
Hi, Most Nokia phone all have similar problem about blue tooth operation failing.
What prompt "Operation failed" is when there an application on your phone , and an application your transferred through blue tooth or any other means has contacted Virus and it's affecting the blue tooth operation.
Solutions to this problem is to restore the blue tooth device back to normal by flashing the phone.
Flashing of phone restore back the lost or corrupted data on phones.To flash a phone, you will need to purchase a device used for flashing of phones. But to save you the cost of purchasing a flashing machine, i would advice you go to the nearest phone repair store around you for assistance. Skill personnel.
Thanks for using fixya..................
1helpful
My nokia 3230 was unable to perform bluetooth operation
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Nov 25, 2010 • Nokia 3230
2helpful
Im trying to turn on blutooth on my nokia 5800 it is coming unable to perform bluetooth operation
Hi,when trying to use a blue tooth and it shows (unable to perform blue tooth operation, Is because the blue tooth is corrupted.
You will need to format phone to restore blue tooth .
First: better use kasperaskey anti virus.
If your desktop pc or laptop has antivirus,
have your pc scan your fon memory through bluetooth, or usb cable
OR:
If you have Virus On mobile
1 - remove memory card.
2 - dial *#7780# or *#7073*
3 - It format your Phone
4 - Format memory card.
and enjoyyyyyyyyyyyyyyyyyyyyyy
OR
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this links.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Aug 20, 2010 • Cell Phones
2helpful
Blue Tooth recieving error ''operation failed'' in Nokia 6233
go to bluetooth settings and put save in memory card
Bluetooyh not working
the blue tooth has a solution.
It is in two ways.
Either the the blue tooth is not pairing well with other devices,
or
The blue tooth is corrupted.
When pairing phones together, make sure you pair the phone properly before you can use the blue tooth with other phones, because if you don't pair properly with another device, you will not be able to send or receive any data.
If the blue tooth is corrupted all you need to do is to flash the phone, that is the only way to restore the blue tooth back to be working.
Have a nice day.
1helpful
Hi i want to turn blue tooth it dosnèt work
The software might have gone corrupt.Please get it updated from Nokia Care.
Problem
reformat your phone.
1helpful
Blue tooth will not pair with my new phone. keeps asking for a pin. i dont recall setting one up and dont have the manual anymore to remember the basic one it came with.
blue tooth will not pair with my new blackberry 8320. keeps asking for a pin. i dont recall setting one up and dont have the manual anymore to remember the basic one it came with.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
