Question about SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader
When i put my 8 gb sd memory card into the computer drive it will not pop up. and when i click on the drive it says "could not function because of an i/o error"
  • 102 Answers
  1. Click the Start button
  2. Right click My Computer
  3. Select Manage from the resulting menu
  4. In the Computer Management window, select Device Manager
  5. In the right pane, click to expand IDE ATA/ATAPI controllers
  6. Identify your CD/DVD drive in the expanded menu and right click the appropriate drive
  7. Select Properties
  8. In the Properties windowswhen i put my 8 gb sd memory card into the - mag-glass_10x10.gif, click the Advanced Settings tab
  9. In the Transfer Mode box that represents your CD/DVD drive (typically Device 1); open the dropdown menu and select PIO Only
  10. Click ok and exit all windows
If this does not resolve your issue, then you will need to go back using the above procedure and change the Device 1 in step #9 back to "DMA if available". Then, change Device 0 to "PIO Only" in the Transfer Mode box.
For reference, the Device 0 is the Primary IDE Channel and the Device 1 is the secondary IDE Channel.
After you change your settings, make sure you restart your system so that the computer recognizes the changes you have made. After you reboot, check the settings to make sure they are in effect. If they are, your device should now work properly.
Posted on Jun 29, 2009
Bought an SD card and it won't format?
Card is not compatible with the camera operating system. Like trying to put a SATA hard drive into an old computer that had IDE hard drives.
You need to refer to the manual for the camera to see what memory is supported.
Google
make model manual
Apr 03, 2016 | Cameras
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
8 GB High speed SDHC card
This video provides troubleshooting steps for memory card problems.
Jun 09, 2013 | Electronics - Others
SD Card Full
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
Mar 25, 2013 | Tascam DP-008 8-Track Pocketstudio
Why wont my computer read my SD card? i have a Samsung TL210 double view hd camera. when i put my 8gig SD card in my computer nothing happens at all i have a vista computer ok. i am 13 years old so make...
If the 8Gb SD card works on your HD camera, then the problem is with your built in memory card of your computer. Most of the built in memory cards of the computer only supports up to 2Gb.
You can actually isolate it by trying to test an SD card lower than 8Gb to your computer.
Solution for this is to use external USB SD reader that supports high capacity SD card (SDHC) or contact the manufacturer of your computer and ask for firmware updates for the memory card reader. Hope this is clear and would help you.
Jul 01, 2011 | SanDisk 8GB microSD High Capacity...
I am having Intel pantium 4 computer that configration is windows 2000, when i am trying to read 8 GB memory card that drive is comming but at a time of try to opend masage is is comming as PLEASE INSERT...
It sounds as if you have an SD card reader, not an SDHC card reader. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. SD devices are limited to cards 2GB and smaller. SDHC cards begin at 4GB and go up to 32GB.
Nov 26, 2010 | PNY 4GB Secure Digital High Capacity...
How can i download a music from computer to my memory card using my card reader,help please
1. First insert your SD card in the card reader.
2. Plug the card reader to your PC.
3. Go to My Computer, you will see the SD card as removable drive.
4. Double click in your card, and open.
5. Again go to my computer, open the a separate window. Open the folder containing your music files.
6. Select the required music file, right click, in the pop up window select copy.
6. Go to your SD card window, right click, in the pop up window select Paste.
7. You will see a window showing coping in progress.
8. After completed the process close the window.
9. Look at the right side of the task bar, there will be an icon, Safety remove hardware, left click, in the pop up menu select your SD card drive, one notification will come, "its safe to remove the hardware"
10. Remove the Card reader from your PC.
Aug 18, 2010 | SanDisk 2GB microSD Memory Card
I want to know what i need to do next after i have put my sd card into my computer, a green light comes on, and i want to know how to get my pictures to come up on my computer, so i can do any adjustments...
1. When you insert a memory card into your computer, it'll be detected automatically and an "AutoPlay" dialog box will ask you to what to do ?
2. Select "Open folder to view files" option from the list.
3. Now, you can easily view the files in the memory card by double-clicking them.
4. If the "AutoPlay" dialog box doesn't appear, goto Start >> My Computer. Here you can view the memory card as a "Removable Drive" with some name!
5. Double-click the memory card's icon to view the files inside it.
6. After your job is complete, you can remove the memory card by just clicking the USB device icon at the right side of Task Bar (Notification Area)!
7. On click, a single option pop-up will appear with "Safely Remove USB Mass Storage Device" message!
8. Just click on that pop-up. A "Safe To Remove" message box will appear.
9. Click on OK button, and manually remove your memory card!
please rate this advice if it helps...tc! :)
Jan 12, 2010 | Electronics - Others
New sd memory card 8 gb keep formating
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Aug 31, 2008 | JVC Everio GZ-MC200 Camcorder
    Open Questions:
    See all SanDisk 8GB microSDHC Memory Card with MobilMate Questions
    SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader Logo
    272 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Carlos Calvo
    Level 1 Expert
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
