Question about Sharp AR-507 Copier
Having weird trouble with copies.When using doc feeder,paper comes out fine but top quarter of copy is blank and rest of page is fine.When I scan from the glass,a full copy is printed but paper comes out slow and curles into a tube on the exit tray.Paper does not curl when I use the doc feeder.Is the fuser too hot?Fuser rollers seem to be okay.Is there a simulation I should try? perplexed, thanks for your help.
  • 1 more comment
  • Anonymous Jan 20, 2008
    show the massge Call for service , code F2-00
  • Anonymous Mar 25, 2008
    sharp ar-507
  • Anonymous Dec 18, 2008
    the same
Scaner does not complete as normal
Posted on Jan 24, 2009
  • 62 Answers
Ckeck the glass on the left side it is about 1inck by 12 inch for white out on it also clean the optics.On your curling problem install fresh paper you can check your fuser temp. in sim 43-1 change it to 180.
Posted on Dec 13, 2007
Why is my photocopier only printing half a page?
Sounds like one of the sensors in the doc feeder that detects the size of the paper has gone bad.
Also, make sure you always close the document feeder when making copies. Sometimes it helps to put a blank sheet of paper over the back of a small object if you're copying something small.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Office Equipment & Supplies
I am having a strip dark line when i do my photocopy
If this problem is happening only when you are copying and not printing, then you can narrow down the problem to the optics area. If you are using the doc feeder to copy, then I would check the small **** glass that the copies slide over; often times dirt or debris can get stuck there and cause horizontal or vertical banding (depending on the orientation of the original.)
Let me know.
Oct 31, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to know if My copier need a new toner
For the toner you will have message that you need exchange it.
How many copies do you have? (press COPY key by the display and hold until the no of copies is displayed)
Where does the paper jams? ( on drum, on fixing roller, in cassete, in doc. feeder,...)
try to clean the pickup, feed and separation rollers
Feb 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
AR-157E blank page when using automatic feeder.
you night check to see if your cable to the copier is connected but this problen iv seen several times not worth fixing the main pcb is usally gone as for as working with the feedder
Feb 17, 2009 | Sharp AR-157E Copier
F-5 error
Manual says F5 as copy lamp lightning abnormality.
Never had on AR series Sharp machines this trouble,but remember on old Canon NP 6016 when lamp was bad -no dark ends and low intensity of lightning but intensity too high.This machine was equiped with doc feeder and customer performed a lot of copies from glass only and I think he was damaged lamp when close the doc feeder.
the fluorescent type lamp was used on this Canon-Sharp uses Xenon lamp (I think),but they could be very common in construction (tube with electrodes on ends and gass inside)
This fault is very difficult to troubleshoot-try another lamp first,next sensor from good working machine.
Nov 13, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Jams but only w/sheet feeder
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Aug 13, 2008 | Sharp AR-507 Copier
Sharp ar-5316 E Problem
Make sure that the side door is secured. There is a corona wire in a brakced on the door and if it does touch the rest of the machine correctly, blank pages will spit out.
Aug 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-507 Copier Logo
185 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
