Question about Toro Lawn Mower With Toro Power Tools
Electric starter not working on Toro
My 22 inc recycler Toro will no longer start using the electric starter. I can use the manual system fine and it runs well. I have changed the spark plug, changed the oil and filter.
  • steven_smoge Nov 05, 2009
    thanks, sounds similar although mine was the battery just died. I contacted Toro and they of course would not cover the new battery. appreciate the response
I've had the same problem (I think) - the starter will not activate. First time, I found the fuse that's attached to the battery "tray" had corroded. For that I put a good coating of silicone dielectric grease on the fuse contacts and holder. This keeps moisture out. With that it was good for a few months. Now it's gone bad again. This time the fuse is good, but the battery is dead, and so dead that it won't recharge. Apparently the cause of the discharge was/is grass and moisture finding its' way into the battery area, and providing a conductive path between the battery terminals. I was recharging it regularly, following the owners manuals' instructions, so it's definitely not a negligence problem caused by me.
So, obviously what we have is a design flaw in the mower that allows grass clippings to get into the battery area. Time for a recall, but for a quick fix for your current pioblem, you might just find the fuse is corroded, and a replacement + non-conductive grease may be all you need to git'er going.
Posted on Nov 05, 2009
  • apokerlm Apr 12, 2011
    The battery tray is always full of grass. Not sure what the engineers were thinking? Even after examining the plastic tray design I'm still not sure if it is a design flaw or or the manufacturing is bad? The cable, battery and fuse do not fit right and why is the grass getting in there? Anyway it's easy to blow a fuse when removing and reinstalling if your not careful with the cable.
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
I have a Toro 22"
Odds are the battery needs replaced. If it is a 12V battery, you could try jump starting to test the starter to verify. If it is a 6V battery you will have to find another one to jump. You could check the battery with a multimeter to check voltage if you have one or know of someone who does. Make sure you know how to do this properly so as not to destroy the meter. The meters can be cheap or expensive, depends on the model and the features, but always bad idea to let out the magic smoke.
I hope this helps.
Jul 27, 2011 | Toro Lawn Mower With Toro Power Tools
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
We have a brand new toro 22 in Recycler lawn mower that we have used 2x and today it stopped working. We are unable to pull the start cord more than 2 inches out so obviously we cant start it. Help.
Check the oil ... does it have oil in it?
Disconnect the spark plug, tip the mower up, can you move the blade? If the blade will not move, the motor may be seized.
No oil = ruined motor ...
If the blade will move freely, there is a recoil starter problem.
Thanks for your interest in FixYa.com
May 15, 2010 | Toro Lawn Mower With Toro Power Tools
I have a Toro 22" Recycler Mower. Never had problems starting before til now. Have gas, oil level fine, new filter and spark plug. Why not start
Youwill need to disassemble the carburetor and spray withcarb.cleaner.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
Just let me know.
Jim
Sep 25, 2009 | Toro Lawn Mower With Toro Power Tools
22'' recycler won't start
TRY A SPARK PLUG, MAY HAVE GOTTEN SOME WATER, MAY HAVE TO CLEAN OUT CARB
Sep 20, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Personal Pace Mower won't start w/ electric starter
There are a couple of things you can check;
First, check to make sure the bendix is engaging. It is the gear that meshes with the fly wheel.
If it is, then try and see how fast the motor is spinning. Don't look at the blade though. It could be a faulty starter motor.
Make sure to also check the battery voltage with a volt meter. It should read at 12.0 or higher.
Sep 07, 2009 | Toro Lawn Mower With Toro Power Tools
I have a Toro electric start 22'' inch lawmnower Model No. 20018 with a Tecumseh LEV 90-120 engine. The mower may be started with the electric start or manually with the cord. The battery was in need of...
It sounds like the starter drive may be jammed. It should not be engaged unless you are using the starter motor. Take the spark plug wire off, put on heavy leather gloves, and try turning the blade by hand to dislodge the starter drive. If it does dislodge, plug the spark plug wire back up and try the pull start again.
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler runs like ****
You will need to disassemble the carburetor and spray with carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals and/or the jet in carb. These portals can become blocked. Replace the diaphragm as well. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,261 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
