Question about Sony Handycam DCR-TRV330 Digital Camcorder
Camera won't turn on with charged battery
Camera won't power up with a charged battery. Will only do so with the power supply.
  • 287 Answers
Bad battery, hoever the battery catcher assembly can fail. Larry
Posted on Mar 13, 2008
Is there another way to charge the camera so that I can turn it on and retrieve what is on it?
You will need either the camera power supply or a charged battery, if don't have a power supply for camera or a charged battery there is no way around it.
Jan 02, 2015 | JVC Everio GZ-MG30 Camcorder
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
If none of the suggested causes helps resolve the issue, then I suggest you bring it in for repair.
Please check the following things when the camera does not turn on.
Possible causes and how to handle them
1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
If your camera does not operate after checking each of these things, or if there is any visible damage on your camera that could be the cause, please contact the nearest Service Center.
May 03, 2012 | Kodak EasyShare C330 Digital Camera
My nikon coolpix 5700 will not turn on, i have bought new battery for it and it just won't turn on. what do i do?
Pleaseremove the Battery from the camera and give a look inside the batterycompartment. Use a spot light & make sure that place are clean , not rusted& the battery connector pin are not bend or broken. After that insert thefully charged battery and try to turn on. If its not turn on then its confirmthe camera internal power supply unit is faulty. For few reason this problemstarted.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.OR2. Thepower supply transformer stop working & need to replacement.OR3. turnon button connection may disconnected.
After visual checking by the technician is possible to say which part isfaulty.
For the confirmation you need to visit a camera repair store. With outvisual survey technician can't confirm you which one of them is faulty. Thankyou.
Dec 04, 2011 | Nikon Coolpix 5700 Digital Camera
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
My camera dosen't turn on
If your camera won't turn on, first of all try to charge your batteries until it's fully charged. If this doesn't solve your problems, check if your battery pack is busted by using your power supply to turn your camera on. If using a power supply solves your problem then consider replacing the battery of your digital camera.
Dec 25, 2010 | Vivitar V7028 Digital Camera
I have to set the date each time I turn on my Nikon S9 camera even when the battery is fully charged
Read the manual to determine my power supply is supposed to re-charge the watch and date power supply. Since this isn't happening and I don't have a recently purchased battery for it, I'll buy a new camera battery to see if it corrects the problem. If it doesn't correct the problem, the internal power supply that runs the date and time feature (2 days without the camera battery in the camera) will have to be replaced.
Aug 22, 2008 | Cameras
Sony Handycam DCR-TRV330 Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
