Question about Canon Office Equipment & Supplies
Canon Image Runner C2058: Paper keeps being jammed at the same location. It happens at the last exit of the copier. When I clear the jammed paper, the image is printed on the paper. It simply could not exit the last pass. Please help.Thanks.
If you've been printing on pressure sensitive paper, residual adhesive (inspite of the backing remaining in place) can adhere to the top of the last exit. I use mild orange oil cleanser and a paper towel to clean the top of the feeder inlet. After that the "accordion paper jam" stops.
Posted on Jul 30, 2014
    Guru:
  • 389 Answers
Two ways. The First, you should consider the condition of the sensor of the output block. He can be conks or falls out, sticks. Possible correct the tweezers, however better apply to service. If he faulty, follows its change. Can try.
Posted on Sep 21, 2009
Canon 2870 image runner. Paper jam error. But no paper was jamed. How to clear this error
sometimes switching the machine off at the machine and switching back on will clear a code fault.
Nov 07, 2014 | Office Equipment & Supplies
My Canon Image runner 2318 keep jamming paper even no paper is not jammed
is this problem only when u copy from the tray or even from bypass.if it is from tray only then ur rubber feedrolls needs to be cleaned with simple wet cloth.if it is from both then u have to check the paper path sensor
Jul 13, 2011 | Canon imageRUNNER C3200 Copier
My image runner reports paper jam and i have followed steps on panel to clear it but to no avail
Is there paper stuck in the fuser? Sometimes you will have to remove the fuser usit and break it apart to clear the jam. Depending on your skill level this is better left to a technician.
Jan 11, 2011 | Canon Image Runner 1630 Copier Copier
Our Image Runner says there is a paper jam but there is no paper in it. Is there a way we can clear this a procede with our job?
The troubleshooting procedures that follow are organized according to location; to find out the location and the nature of a jam, use service mode (COPIER>DISPLAY>JAM).
Oct 19, 2010 | Canon imageRUNNER 5000 Copier
Canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Canon imagerunner 2230
YOU HAVE A PROBLEM WITH THE PAPER FEEDING CENSOR. IT COULD BE OUT OF PLACE, BROKEN, A PEICE OF PAPER STUCK OR PULL OUT THE DRAWERS MAYBE PAPER STUCK INSIDE. GOOD LUCK
Aug 04, 2008 | Canon Image Runner 3320I Copier
My cannon super 63 image runner 1370f
look on the control panel if there is a diagram of your printer it will usually light up the area where the paper jam is located.
once you find location of paper jam there is normally a green knob in the area of jam that when you manually rotate it will release paper also open paper drawer check for jam or unplug and plug copier back in somtimes this will force paper out as it resets
Jan 13, 2008 | Canon IMAGERUNNER 6570 Copier
Canon PC-795
The blinking light with the squiggle symbol is the display for a paper jam. Not sure a service manual will help in this situation other than to be a guide as to where the paper sensors are located. There are usually 3 or 4 paper sensors located in Canon PC copiers. The first sensor will be located between the paper pick up assy and the vertical rollers*(*which are located behind the door on the right hand side used for clearing jams). The second sensor is located under the toner cartridge just before the registration rollers. The third sensor (if present)is located at the entrance of the fuser assy (some models of Canon copiers have omitted this sensor)The last sensor is located at the exit of the fuser assy. I would suggest that you remove the cassette, verify that a piece of paper has not been partially fed or ripped in the pick up assy. With cassette out of machine, open right hand door & verify that there is no jam and check that the flag or arm of the sensor moves freely. Remove the cartridge from machine and again verify there is no jam and the registration sensor arm moves freely. If there is a sensor in front of the fuser assy, verify that it also moves freely. Finally, check for a jam and sensor movement at the exit/fuser. After checking all sensors, unplug the machine and plug back in. (Do this without the cassette & cartridge installed but with all the covers closed) This should give you an install cartridge & cassette message. Install cartridge first. This should give you the install cassette message. Install cassette. If you still get a jam signal when plugging the machine in without the cartridge or cassette, the most likely cause is a blown sensor.(rare, but I have seen it.)If this happens you would then need the service manual to disassemble & repair. I'll keep an eye out for your reply! Good Luck!!!
Jun 06, 2007 | Canon PC-795 Copier
78 people viewed this question
old marine
old marine
