Question about Dell E152FP 15" Flat Panel LCD Monitor
Screen flickers up and down, like the horizontal hold is bad
  • jesspow Jun 29, 2009
    The monitor is hooked up via KVM siwtch to two PCs, and the problems persist no matter which machine I am using. Also, I have already checked the KVM, by plugging the monitor directly into one of the PCs and the problem continues. So I'm pretty sure it's distinctly a monitor problem, and not a video driver, unless my video driver suddenly went bad on both of my machines simultaneously?
    Sergeant:
    Champion:
  • 233 Answers
  • Satya Santhosh
    Satya Santhosh Jun 30, 2009
    I believe the issue might be with the monitor as you said. I suggest you to contact your monitor support.
LG TV Flickering horizontal lines
The TCON board or the LCD panel is faulty. Can confirm By replacing the TCON board
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 23, 2016 | LG Televison & Video
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
My screen flickers and goes out sporadically.
Bad video graphics chip on logic board. Probably made by Nvidia. Repair logic board or replace the logic board.
Feb 17, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Horizontal line across middle of screen. screen flickers from that line down. what do i do?
Anytime you get lines on the screen that means the lcd is bad and needs to be replaced. As far as the flickering problem is concerned that can be a problem with the lcd and that would go away as well once you replace the screen or it could be the inverter which supplies voltage to the lcd and its a little board that is underneath the lcd.
Apr 09, 2009 | Toshiba Satellite L305D-S5895 Notebook
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Compaq presario v2000 monitor is having horizontal purple lines that flicker.
Try reloading the drivers, delete the device in device manager and reboot. It should then pick up the drivers and reload them, if that does not work I would suspect the screen is on its way out (flickering normally means the screen or its connection is bad)
Jan 26, 2008 | HP Compaq Presario V2000 Notebook
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
sounds like a problem in the horizontal deflection circuit.possibly a solder problem. try re-soldering the horizontal transistor, line coils and yoke pins.
Sep 01, 2006 | Toshiba 50H81 50" Rear Projection...
Dell E152FP 15" Flat Panel LCD Monitor Logo
119 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
