On the front of the brew unit there is a circle, part of a hole through the center of it. If your look closely you will see two index marks in the shape of an arrow - one small - one large - the arrows need to be pointed towards each other in the "Home" position - this lines up the cam with the drive unit - both in the "home position. You can use your fingers on the piston assemble to move the index marks to the proper position.
SOURCE: brew unit
Make sure you have brewing unit in start positions, if you have a press on your brewing unit make sure to press it to you hear a tick, then you can fit it in the machine.
