Question about Singer CE-100 Futura Computerized Sewing Machine
The manual doesn't explain how to thread bobbin correctly
I can't do it either! Please someone help. This machine is a birthday present and it cost my husband £800! It's unuseable if I can't work out how to make the bobbin 'click'
    Problem Solver:
  • 9 Answers
You thread the bobin by putting spool on post and then winding around the tension thingy.
I looked on line and saw a video how to do it
Posted on Jun 29, 2009
Testimonial: "I found the video online too. Thanks"
How do i fix my sewing machine underthread keeps breaking
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Nov 04, 2012 | Sewing Machines
Underthread in sewing machine keeps breaking
I am assuming your talking about the bobbin thread, so that is
the information I am sending you
Nov 04, 2012 | Singer Sewing Machines
Kenmore bobbin issues
try these suggestions
Oct 25, 2012 | Kenmore Sewing Machines
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
The upper thread will not pick up bobbin thread
Make sure the needles are the correct size, fully inserted into the needle bar and oriented correctly for your machine. If that doesn't work check the timing. The hook should arrive at the needle scarf when the needle is at the lowest point in it's travel. If it doesn't... go have it timed by a pro.
Aug 28, 2012 | Singer 1507
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
After I sew I can pull the bottom stitching right out. What causes this? Help
The problem is most likely thread tension. First try loosening the upper thread tension (numbered wheel on left side of most machines), if this doesn't rectify the problem then check the bobbin case tension. Correct bobbin case tension can be verified by holding the bobbin case with bobbin inserted and thread extended several inches. If you grasp the thread the bobbin case should not descend rapidly (fall) but should unspool slightly when thread is quickly tugged upward. Please refer to attached picture or your owner's manual.azcouture_1.jpg
May 15, 2011 | Brother LS-1217 Mechanical Sewing Machine
How do I thread my bobbin to my brother xl-5130
Here you are....download the manual for free.
http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL5130
Mar 24, 2010 | Brother XL-5130 Mechanical Sewing Machine
Looped bottom thread
Sorry I missed your problem, I have just signed up on here to help with problems like yours.
Thread looping underneath the cloth is a bobbin tension problem.
Folks in general are not aware that in addition to the top tension being set correctly so must the bobbin tension.
It is impossible to explain how to do this you need to be shown. However it should be explained how to do it in your manual.
Jan 29, 2008 | Janome Mini Compact
Threading my bobbin and correct tension
If you go to this link, it shows for the 117.591 model, but it is threaded the same exact way as the 117.959, that will thread the machine and bobbin, I have used this to thread my machine which is the 117.959, and it sewed perfectly until I started messing with the tension, I still haven't figured that part out yet, but I will and when I do, I will let you know. You should be able to thread the bobbin correctly with the manual, if you are pulling the bobbin through the hole the needle is going down in, your bobbin is threaded correctly, if the problem is like mine, your not making stitches, the problem is with the tension. I hope I have helped and if not, sorry.
http://sewusa.com/Threading_Diagrams/Threading_Pages/Kenmore_Sewing_Machine_Threading/kenmore_117591_threading_diagram.htm
Jan 27, 2008 | Sewing Machines
Singer CE-100 Futura Computerized Sewing Machine Logo
118 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
