I need help please ,give me the code of samsung c3510 tazdijaja jsdl djsl kjsdl ljsdl lsdlj ljsdljsldj lsdljsldj lsjdjlsdlsdsjdl ldlsdlskld ljdlsdl lsdlsldmkjskd qmjsdkqjskd qjsdkjqskd qkjsdklqjsdkj qksjdlkqsdj qkjsdkqksd qlkjsddlkqjsd qsjdlqksjdlkqsd
SOURCE: need puk code for samsung gt c3510
Service Provider will give the PUK Code....You can call them...
SOURCE: need code to unlock my phone game samsung c3510
Decoding the patterns of Samsung
The first step in decoding is to remove the SIM card's phone without sim and restartingit.
Step two is to introduce the following code * # 2767 * 3855, after entering the code wewill see this message FULL E2P RESET.
After the message disappears displey will enter a second code * 2767 * 2878 #CUSTOM E2P following message will appear RESET.
Once this message disappears, it will enter the last code # * 7337 #, then we will comeand long awaited UNLOCK message.
Warning! Codes must be entered only in the order I gave.
Method personally tested many models of phones.
do not forget to vote that helps us help others
SOURCE: My samsung gt c3510 don't work application like
Only Java applications work with Samsung gt c3510.
SOURCE: i have samsung C3510 Genoa.
Enter this code in standby mode: *#52828378#
You will see "JAVA Test Menu" screen. Select option # 6 which is "OTA Test". Here you can see "Maximum JAR size (KB) which is 400 KB by default. Just enter your own value like 2048 KB. Press "Save" and exit from it. Now you can install JAR file of upto 2 MB size. Keep in mind that your new setting (2MB) will change back to default value (400 KB) if you RESTART your mobile. So, this is just a temporary setting but works perfectly to install large JAR files.
