Question about AdobeAir Mobile Swamp Evaporative Air Cooler Air Conditioner
Evaporated cooler is not filling up with water
We have an adobe air evaporated cooler that is not filling up with water. is the water pump bad?
  • 37 Answers
Yes ur water pump is not working properly..
ur will have to check it
Posted on Jun 29, 2009
Hi, I've just purchased a farm house with a Vulcan Bonaire evaporative cooler installed. My problem is that it leaves our tiled floors very wet, which is very slippery and dangerous.
replace the float valve in the water tray
evaporate coolers work by pumping water onto a screen through which air is blown
the hot air evaporates the water in the screen and the air out is cooler
works very well in hot dry climates but not so well when the humidity is above 80%
Nov 29, 2017 | Vulcan Heating & Cooling
Bonaire evaporative cooler not pumping water on the pads
Make sure its on cooling not just on fresh air / vent setting. If the pads are not getting wet and the control is on cool fresh air, either A/ The machine is not filling with water or B/ The pump has failed.
Nov 22, 2017 | Heating & Cooling
I have a Taiwan evaporated cooler, 120 vac 60 Hz 85 w. Does this unit cost a lot of electricity to run, or is it fairly energy efficient
evaporative coolers use a principle of blowing air though a filter that is water moist
the air passing through the water uses a heat exchange process as the water boils off, the air is cooled and so you get cooler air
very efficient in places where the humidity is under 80% but over that the water doesn't evaporate all that readily and so the effectiveness is reduced
basically the hotter the day and the lower the humidity the more efficient they are.
Cheap --yes as it only runs a small motor for the fan and an even smaller motor for the water pump, but you will need a regular water supply some units have a small tank which needs regular filling and others can be connected to the home water supply
it is not an air conditioner , simply an air cooler.
Jun 15, 2015 | Heating & Cooling
EVERY HOUR OR SO WATER IS POURING OUT OF THE DRAIN, WHY?
There is a float in the evaporative cooler that will let water in when the trough is low and then when it fills, should shut the water off. I would check to make sure that the float arm is not corroded or misaligned.
Aug 17, 2011 | Mastercool 67471 Evaporative Cooler Air...
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Heating & Cooling
My evaporative cooler is only blowing warm air through the home, even though the water is on and all windows are open. Can you help?
Check if the water is getting into the unit. check if it is pumping any water over the filters. cooler will meet its limits at 90% humidity plus
Dec 31, 2010 | Mastercool 67471 Evaporative Cooler Air...
I have 550 CFM cooler and the air is blowing but
you need to open up and clean the pump unless gravity fed but still need to cleaned. or new pump.
Jul 11, 2009 | AdobeAir Adobe Air 550 CFM Portable...
Evaporative cooler pumps in dust
You should not have dust. Your water pump is probably shot. The hoghair might need to be replaced or the whloe unit might need a good hosing down. As far as a draft all the time? That is what you want in an evaporative cooler ain't it?
May 16, 2009 | Mastercool 67471 Evaporative Cooler Air...
AdobeAir Mobile Swamp Evaporative Air Cooler Air Conditioner Logo
445 people viewed this question
Top AdobeAir Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an AdobeAir Heating and Cooling Expert? Answer questions, earn points and help others
