Question about Dyson DC25 Vacuum
DC25 Overheating after a filter cleaning
I have a DC25, about 4 months old. After lots of use, it seemed as though there was a lot less suction that it used to have. I cleaned the filters, using the method described on the little stickers on the filters. After replacing them, it seems as though the suction is even worse! I opened everything up to see if there was a problem, and the motor is *hot*, hot enough to cause the plastic protective screen on the motor's filter to warp a bit. Any suggestions?? Thanks!
  • 75 Answers
You need to not use this until you get it fixed at a vacuum store.they can probably help you with it.might be there is a short or a little water got on the motor.
Posted on Jun 29, 2009
I can run my dc17 to clean my floors but when I put it upright to use the wand it turns off
I called Dyson and they walked me thru the process of making sure nothing was blocking the airflow and suction. Everything seemed fine (not blocked). We couldn't figure out anything on the phone and I was still having the same problem.
Trying to figure out the solution, I removed (entirely) the filter that you're supposed to clean every 6 months and ran the vacuum (I cleaned this filter 2 months ago). It worked! I cleaned the filter (again!) and let the vacuum run and it seemed fine.
I can understand why they won't instruct you to completely remove the filter but it would save a lot of time if they just had you check ALL the options.
I hope this helps!
Longmont Epoxy Garage Floors
Sep 10, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson DC24 has very poor suction - all filters clean and hoses seem to be clear. had it for just over a year
I'm sorry to hear your DC24 doesn't seem to be picking up as well as it should be. From your description of the issue, it sounds as if there may be a blockage in the machine - to locate and remove this, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
You may also want to take a look at the video below to make sure you've washed the filters as we recommend. Use cold water without detergent, and allow at least 24 hours for them to dry completely somewhere warm before replacing them. In normal use, this should be done at least once a month.
I hope this helps - if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 10, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Low suction
Hi Megan,
I'm sorry to hear you're having difficulties with your DC17. If it doesn't seem to be picking up as well as usual, you may have a blockage somewhere in the machine. To check for this, please follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
Although I note you've already cleaned the filter, please see the video below to check you've done it correctly. In normal use, the filter should be washed at least once every 3-6 months in cold water. Don't use detergent, and allow at least 24 hours for it to dry completely before replacing it.
This should resolve your issue, but if you need any further assistance, please call us free on 1-866-693-9766, or email askdysonUS@dyson.com so we can help.
Kind regards,
Jack
Dec 18, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The vacuum seems to have lost a lot of suction power and it is only a month old. Seems like there is a clog or something, all filters are cleaned and after a vacuuming session, nothing is in the...
sounds like there is blockage in the suction hose -- lay the machine down and remove the lower floor plate and clean out the hose area where it bends down to the floor unit ( use a wire coat hanger to fish out the blockage ). also check the main hose for any obstructions.
c...
Feb 17, 2011 | Bissell Cleanview Helix Deluxe Bagless...
Suction always seems very poor
you have to have something clog somewhere
Feb 09, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Dyson 18 losing suction
Check the HEPA filter if it has one. This bit of foam gets clogged over time and significantly reduces the suction especially if you've been vacuuming a lot of very dusty areas i.e. dust from building work etc. Just wash the filter with lots of water and leave to dry before reinserting.
Jan 02, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Vacuum seems to have a problem
Take off the bottom plate and check the inlet to see if it is clogged and make sure the belt is ok. If no clog there, then it is in the hose. If you can't figure it out and is less then 1 year old, then it is under warranty, take it in for repair along with your proff of purchase.
Feb 08, 2008 | Vacuums
Dyson DC25 Vacuum Logo
441 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
