Question about Sewing Machines
Foot control does not work only on full speed
    Top Expert:
  • Sewing Machines Master
  • 80,531 Answers
REPLACE THE FOOT CONTROL, THE VARIAC IS DEFECTIVE IN IT.
Posted on Jun 29, 2009
  • orchestradam Nov 04, 2010
    Most likely the suppressor capacitor has gone short circuit. A replacement can cost less than £1.00. It's connected between the two leads inside the foot controller. You can check the old capacitor by disconnecting it and seeing if a torch bulb will light up when connected in a triangle with it and a 6-volt battery. If the bulbs lights up, the capacitor is dead! Try Maplin for a replacement.
Viking rose 609 model foot pedal will not work
I would suggest you replace the foot pedal speed control.
Jan 10, 2017 | Sewing Machines
How do I fix my 1975 Elna SU which is sewing at full speed even though my foot is off the foot control. Had to remove power cord to stop it !
Your foot control is needing to be either repaired or replaced. Here is a good web site for replacements:
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
Jul 27, 2015 | Elna Sewing Machines
My janome feedomatic compact sewing machine gone's wild. As soon as i plugged it on,itautomatically runs at full blast! Can anyone tell me what's wrong? I cant see any auto buttons on
unplug the foot controller to eliminate it as the problem ,however if the machine does not run like mad as soon as you switch it on
without the foot pedal then you have isolated the problem to the foot pedal,it could be stuck on full speed .
Len..
Oct 14, 2014 | Janome Sewing Machines
I have acquired a necchi automatic supernova. I want to know how to install a foot pedal - it never came with one. It did come with a sewing motor controller (dark brown/black block with two cables leading...
foot pedal is a HD voltage regulator that controls the motor speed by simply increasing/decreasing voltage supply. e.g. if the two wires to the foot pedal were connected the motor would get full voltage and run at max speed. most foot pedals can be adapted for your machine
Feb 16, 2014 | Sewing Machines
I have a Bernina 830, bought in 1978. When I depress the foot pedal, nothing happens. Power is on. Do I need a new pedal?
I've just fixed this problem by replacingthe main capacitor in the foot pedal. I have a Bernina 830. I needed a soldering iron, and I had to buy the right capacitor, but it fixed this exact problem. Btw, a few months ago this problem initially appeared (on my machine) as an issue where the speed was either zero, or full speed). After a white it wouldn't work at all.
Jul 23, 2010 | Bernina Sewing Machines
Elna supermatic...the light comes on ,,but nothing else works
Turn the machine on, press the foot control down and turn the handwheel backwards. If it sputters, the motor carbon brushes are worn to the springs and need replacing.
Next, while pressing on the foot control, try wiggling the wires around where it enters to machine and where it enters the foot control. There may be a short in the cord. If the short is at the machine, you need a new cord. If it is at the foot control, the cord can be pulled into the foot control, the shorted part cut off and the connection reattached.
If it still doesn't work, try removing the cord from the machine and placing an alligator clip test lead to two of the inlet prongs on plugging it into power. Which two prongs you ask? Try several combinations, (one will light up the lamp) CAREFUL: THE MACHINE MAY SUDDENLY TAKE OFF AT FULL SPEED, SO REMOVE THE BOBBIN, THE THREAD AND NEEDLE FIRST. if it runs, it is your foot control. If it doesn't run, it's likely the motor brushes or motor.
Dec 11, 2009 | Elna Sewing Machines
The foot control is not working
well particular on electrical problem foot control is a switch of motor that deliver speed varies on how you press the foot pedal it consist of circular thick plate carbon the old model and the new one electronically control of power ic,It depend on how this pedal was contro.Anyway besure the power is off or unplug the machine; this control was been connected in series connection to the motor which you can test if your foot pedal control is defective. Disconnect the line wire holding foot pedal from the terminal inside motor assembly.If your not qualified electrician don.t do this.Connect the two terminal wire that inside the machine where the motor mounted.This connection is supplying your motor in full speed,Declucth your machine from the handwheel so that the motor run only.Plug the machine and switcn but you must jug only if the motor run in couple second of course without the foot control this was disconnected already.So your foot control is defective vice versa if motor does not run without foot control motor is busted.
how to fix if foot contol is defective, in carbon type you must replcace the circular thick carbon.On Electronic control check the IC if this open or some capacitor and resistor are open,Replaced any pars that had been short circuited.If the motor is defective replaced the carbon brush mounted at two side of motor case,There is an opening port.The carbon brush has spring holding push this carbon brush to the brush armature of rotor.
Mar 06, 2009 | Kenmore Sewing Machines
My machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Jan 02, 2009 | Necchi 3101 Mechanical Sewing Machine
Foot control has no power
Aug 31, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
