Question about Motorola Mobility H500 Wireless Headset
An unknown error occurred with your bluetooth software licence
I have install the h500 i cannot hear anything. i remove it and i try to reinstall it i have tthis message: an unknown error occurred with your bluetooth software licence
what can i do please help
HOW TO CHANGE BATTERY HEADSET H500
Why do you think you need to replace the battery? A common sign that your Motorola Bluetooth headset needs a new battery is when you repeatedly hear five quick high tones in successive, one-minute intervals. Another symptom of a low or dead battery is when you try to scroll to Power and your headset doesn't come on. The Motorola H500 headset has a long battery life, but the battery eventually will go bad. Unfortunately, the battery is integrated as part of the headset's circuitry and should not be replaced by its user. Motorola strongly advises against trying to change the battery. Attempting to replace the battery voids the headset's warranty. By sending the headset to Motorola for repair, you can have a new battery installed without the risk of damage to your equipment.
But you can try the following at your own risk:
Locate the battery door at the rear of the headset and open it.
Remove the old battery. Install a new battery to match the plus and minus illustrations on the battery compartment. Shut the battery door back in place.
Select "Menu" on your phone. Select "Settings."
Select "Connection," "Bluetooth Link," and "Setup."
Select "Power." Select "Change."
Select "On," and then press "Select."
Press the "Call" button and hold it down. Release it when the LED light blinks.
Oct 11, 2014 | Motorola Mobility Universal Bluetooth...
Kodak esp 5250 printer error has occurred
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Nov 21, 2011 | Office Equipment & Supplies
A problem occurred when windows tried to activate. Error Code 0xC004F063. the Software Licensing servies reported that the computer BIOS is missing a required license.
I can tell you why you are getting this error. How to fix it depends on the reason you are getting this error.
Windows software licensing means that a copy of Windows is only valid for a Single PC. As part of the installation process the Licence key is linked to the motherboard of the PC.
The error is telling you that the Licence key you have for Windows has been activated and linked to a specific Computer B IOS. You can re-activate it on that computer, you cannot install it on another computer.
There are 3 reasons you can be getting this error
  • You have changed the motherboard or the BIOS chip in your machine and you are re-installing Windows. The Licence will not be accepted and this breaks MS licensing agreement.
  • You are trying to re-use an existing Windows Licence on a different machine - Not allowed using a OEM (operator installed) version of Windows.
  • You have reinstalled Windows on your machine using a different installation disc - this can cause confusion when re-installing an OEM version of the software. e.g. Dell branded OEM Windows will only install to Dell machines.
Assuming the licence is valid for the machine and the Motherboard you need to Contact your machine provider to get a valid installation disc - they may well charge for this service.
Jan 23, 2011 | Computers & Internet
Every time I bring the computer up I get a notice Bluetooth software licence not found [2]
reinstall the bluetooth driver from the control panel and reinstall the bluetooth driver from the driver CD/DVD. this will solve ur problems.
OR, Open the Device Manager and there you will find a option namely NETWORK ADAPTERS. click on it and uninstall the Bluetooth Device (RFCOMM Protocol TDI) and then install from the same place and same way.
thenk you
Jan 01, 2011 | Dell Studio 1537 Laptop
A problem occurred when windows tried to activate. error code 0xc0o4e003
Software activation licence issue, where Vista reports the wrong key entered...
Usually occurs when using a copied vista disc to install even when putting in own licence key
Try this:
Click the Start icon (Windows ball in the bottom left of screen)
Click Computer then Sytem properties
In windows activation, click change product key
Enter your ORIGINAL product key
see if that works
Dec 28, 2010 | Computers & Internet
I am trying to connect my H500 to my new
Enter '0000' (four zeros) when your phone requests a passkey whilst pairing with your headset.
Hope it works for you.
Cheers! Carlos
May 17, 2010 | Motorola Mobility Universal Bluetooth...
Dell Studio Bluetooth Not Working
if ur OS is windows 7 it does not need any bluetooth soft..
Mar 02, 2010 | Dell Studio 17 Laptop
Phone "finds" unknown device.
After I posted my problem, I tried one last thing, I "rebooted" my phone; turned it off then back on.
After I did that everything worked fine.
Nov 06, 2008 | Motorola Mobility H500 Wireless Headset
MOTOROLA H500
I CHARGED MY BRAND NEW MOTO H500 HEADSET FOR 3 HRS CAME BACK AND BLUE LIGHT WAS OFF. THAT MEANS FULLY CHARGED. WHEN DISCONNECTED FROM CHARGER. I TRIED TO TURN IT ON AND NO LIGHT OCCURED. FLASHING.. STEADY... PULSING... OR ANYTHING
Jun 15, 2008 | Motorola Mobility H500 Wireless Headset
Can not hear on bluetooth
my headset works fine if I get a incoming call.When I dial out no one can hear me.
May 09, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
824 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
