Question about Steam Fast SF-275 Steam Max Canister Vacuum
When I push the button to release steam on the handle it feels soft and no steam is released. It has been going out for a while now.
I didn't fix the problem but I did take the handle apart. There is a little metal piston that is pushed down by the button on the outside of the handle. It was very sticky and stuck in the off mode. I freed it when I took it apart but obviously it just stuck again. I am going to take the handle apart and see if a little WD40 will make it easier to push. Either that or glue it in the "on" position. I really love this appliance and if I can't fix it, I'll probably just buy something similar.
Posted on Jun 30, 2009
Yello steam mop does not make steam
The release lever is held in place by tabs molded into the base. You just need use a screwdriver or two to press the plastic tabs back and then push the release lever out. The new release lever can be just pushed into place and the plastic tabs will snap and hold it in place.
Feb 13, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark s3601a no steam
Don't you have to push down on the handle while mopping the floor to get the steam to release. I know the one I have has a handle that slides down the shaft in forward mopping motion which releases the steam.
Oct 15, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The unit heats up when plugged in, but there is no steam released out the bottom of the mop when the handle is pushed up and down.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Dec 21, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Wheres the release button for the recovery tank located on model # 2591
There isn't one. Just pull the handle straight up. When you reinstall it be sure to push it in firmly. Mine gives a click. Otherwise water runs out the side.
Nov 11, 2010 | Eureka Atlantis 2591A Upright Steam Vacuum
It will not dispense water when you press the release button
I've had a problem with Bissells where the handle gets out of where it's supposed to be in the handle and causes the problem that you mention. If this is your problem, the handle will feel different and looser. Good luck!
Mar 13, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
How does it work?What do you push to release the steam?
Push and pull the handle like your mopping...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
heatman101
Nov 08, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Steam Fast SF-275 Steam Max Canister Vacuum Logo
271 people viewed this question
Top Steam Fast Vacuums Experts
Are you a Steam Fast Vacuum Expert? Answer questions, earn points and help others
