When driving the gages will freeze in place an when I turn the vehicle it will not restart without unplugging it for about an hour.my vehicle is a 2006 ford explorer
SOURCE: 91 ford ranger fuel gage troubleshooting
drop the fuel tank and check the pump. if you cant, then you can check the wires for the pump.
SOURCE: 1994 ford explorer dies while driving
Easy Fix! I know exactly what ur talking about, had the same problem for ******* ever, and its not the fuel pump, trust me!!! and it will cost you absolutely nothing to fix! I don't know what the hell they're called exactly, but on the right side of your engine there's a black box, next to where you put the coolant in, with fuses in it. They look like one inch cubes and will say Ford right on top. One of them is for the fuel pump. Try switching it with one of the others, or just switching all of them around and ur car will fire up, but the one that's not working will cause something else not to work properly, but at least u'll now what the problem is. Than just do what I did: take one with you and go to a junk yard and pull out a bunch, they're the same on many ford vehicles, even the newer ones, like 2000, not just the explorer. Make sure its the same one, pull out a bunch, put em in ur pocket and leave without paying, nobody will notice anyways, but they're tricky to find at a parts store, surprisingly. When ur car is running beatiful again, come back to this post and tell me if I was right! God knows how many ours I spent in that car stranded, waiting for it to fire up. Sometimes it'd be 5 minutes, sometimes an hour, sometimes hours, even days. Never knew when it would or wouldn't. Thought is was the starter too! If it works, tell me!!!
Testimonial: "you have helped me out so so much you were exactly right and also it happened to my sons dodge neon and it was the same solution thank you so so much "
SOURCE: Ford Explorer 2006 Overheating
Who determined that the water pump and radiator needed to be replaced? If it was the dealer or an independent garage, bring it back and tell them they guessed wrong. You paid to have the problem fixed and they need to stand behind their work.
This is a problem that's hard to diagnose without being able to check a lot of items and ask questions, but the obvious things to look for if you have a new radiator and water pump (and hopefully a new thermostat) is for air in the cooling system which keeps the coolant from circulating. Also check to see that the cooling fan(s) are operating properly.
SOURCE: I have a 1998 Ford Explorer with a
check gauges is basically to get your attention your real problem could be fan belt is broken if not grab fan blade with engine off. see if there is any play in the water pump bearing if not then its going to be a thermostat the head gasket will also cause it to overheat but you didnt mention white smoke coming out of exhaust so that is not the problem
SOURCE: 2006 ford explorer. ignition won't turn after
fords had recalls on the shifter bushing if you have colum shifter the bushings came loose causing slack in ignition swith check that ,also most of taurus and others that had the same problem it gets worse over time
